Results 1 to 10 of 10
Thread: How does one completely delete the knock sensors?
    Jun 2005
    Question How does one completely delete the knock sensors?
    Got both codes and I don't wanna waste time chasing down the problem whether it be a pinched wire, bad harness, or bad sensor(s). (nor do I have the time or resources to do so :( )
    How do I delete them in the tune so it doesn't throw the code and pull timing? Maybe SpeedDemon could chime in?
    Thanks!
    Christopher's -10cc Alum 6.6L '01 T/A FIREHAWK Recaro Topline Leather/Suede Seats
    Ported L92 Heads, Custom Cam, L76, F.A.S.T. 90TB, 104Lid, CLSD, Kooks 1 7/8 stepped 2", 3" True Dual X-pipe over-the-axle, 3.90 gears, Tubular K, Upper/Lower tubular A-arms, full UMI suspension, etc.
    Brenda and Her Custom Red/Black '01 WS6 Performabuilt stalled A4, Custom Cam, Kooks 1 7/8", 3:42, lid/K&N, Loudmouth, Full Custom Interior, Playboy Package.
    Jun 2005
    Quote Originally Posted by the Dragon View Post
    Thanks!
    How funny. I just did this the other weekend when I got the car out. I think it worked. But, I was bad because I didn't log to verify like I should have.
    Anyway, I zero'd out the knock sensor sensitivity table (B6228) and disabled the (3) knock sensor related fields in the DTC Processing Enablers (C6001). Hopefully, that took care of it. I know it made the Check Engine Light go away. If it's still pulling timing, I'd zero out B6204 and B6205 next.
    Now....can you please explain the links in your sig?
    Jun 2005
    Lightbulb
    Thank you for the info and help!!!
    LOL about the link question
    The Girl is my Wife
    She's an international print model whom was recently signed with Playboy
    Quote Originally Posted by SSpdDmon View Post
    Nov 2006
    I'm wondering why you would do this.
    LC-1 WBO2
    Oct 2006
    Quote Originally Posted by mr.prick View Post
    Post links to a pic of his wife or delete the knock sensors?
    If she was my wife I would let everyone know too.
    The Tremor at AIR
    Jun 2005
    Question
    What about setting B6214, B6215, and B6257 to 8000?
    Or to an rpm higher than one's rev limiter?
    I'm just curious about all the possible ways to do the same thing
    Jun 2005
    Lightbulb
    If you're throwing one or both of the following codes 332 or 327 it can be time consuming to say the least in order to track down the problem AND fix it.
    If you search here and/or on tech you can read about people who have replaced wires, sensors, and harness' only to have the same issue exist 2 months later. Therefor, a great deal of time and money was exhausted with no return.
    If one's car is tuned properly and there is no lean condition the knock sensors aren't really needed. They aren't even used by all car manufacturers today.
    Nov 2006
    Quote Originally Posted by 5.7ute View Post
    Delete the knock sensors.
    When I posted there was only 2 posts, weird.
    LC-1 WBO2
    Jun 2005
    As long as there's no loss in timing from KR after what I instructed above, I'd say leave well enough alone. I'm sure there are other ways. Once you find one that works though, I'd go with it.
    As for why I did it, I just haven't gotten around to replacing my sensors, harness, etc. I figure I'll do it once. If it doesn't like me after that, I'll consider deleting them again permanently. I tend to run a fairly mild tune. So, not having knock sensors is something that doesn't seem too frightening to me I guess.
    Jun 2005
    Smile
    Sent you a pm
  1. No knock sensors???
    Last Post: July 9th, 2016, 07:28 AM
  2. Knock Sensors off
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: September 12th, 2009, 03:12 PM
  3. Where to desensitize knock sensors?
    Last Post: October 19th, 2006, 01:32 PM
  4. 98 knock sensors
    Last Post: June 10th, 2006, 10:12 AM
  5. LS2/LS7 Knock Sensors and LS1/6 PCM
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2005, 10:55 AM
