Results 1 to 3 of 3
Thread: 2000 gmc seirra 4.3 won't start after attempt to read pcm!!!
    Mar 2005
    Default 2000 gmc seirra 4.3 won't start after attempt to read pcm!!!
    I just recently tried to read my friends 2000 Gmc sierra 4.3. Flashscan did not recognize it. Now it won't start. I turned the key to run and pulled the ecm bat fuse for 30 sec. THe truck primes because I can hear the fuel pump. I turned it over and it catches and then just cuts off. The lcd screen says security but all the gm trucks i tuned and seen show the same thing. I wouldn't think just because I tryed to read the pcm it would shut down.
    I talked to Blacky and he thinks its vats. How can I try to relink vats thanks
    Mar 2005
    Sorry Guys I just freaked out. It started now. Its one thing if I'm stranded, but if my friend is stranded because of me thats different. Guess the pcm freaked out.
    Aug 2004
    Efilive can only do the ls1 based computers. That computer in that truck is the vortech Black computer with 4 plugs. That is why it didnt recognize the pcm. You need to unplug the 4 plugs on the computer for about 10 seconds, then the vehicle should start back up. If not, Email me personally, ill send you out another pcm.
    The 4.3s that can be programmed by efilive are 2001 and up. That is when they switched to the 1220411 pcm.
  1. Hard start condition with 5.7 in 2000 S-10
    By lowriders10 in forum Vortec V6/V8 Specific
    Last Post: May 30th, 2010, 03:56 PM
  2. Tr230 cam first attempt
    By Slowrc in forum Gen III V8 Specific
    Last Post: May 24th, 2008, 04:09 PM
  3. Can't see the Roadrunner when I attempt to connect via EFILive
    By the Dragon in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 5th, 2007, 03:39 AM
  4. newbie with start issues 2000 vette
    By robiwan in forum General (Petrol, Gas, Ethanol)
    Last Post: June 30th, 2006, 04:10 AM
