Results 1 to 10 of 10
Thread: VS Commodore wont detect chatter
    Jan 2009
    Default VS Commodore wont detect chatter
    Ive bought the full version and am having problems.
    I bought it for my modified VS but cannot detect chatter.
    It works fine on my VT, i immediately swap over to my VS and nothing.
    My memcal on the VS is re-burned and the VT is stock.
    A little bit annoyed...
    You need to use different vehicle definitions for most different vehicle/engine combos:
    VT V8 uses: gmh-vt8.xml
    VT V6 uses: gmh-vt6.xml
    VS V8 uses: gmh-vr68vs8.xml
    VS V6 uses: gmh-vs6.xml
    Also, the VS V8 does not chatter, so you won't see any chatter when connected to the VS V8.
    Jan 2009
    Im using the right definition for the VS V6 gmh-vs6.xml. It just wont connect. Ive tried every different combination and nothing.
    Jan 2009
    Does anybody have any idea? Ive got a problem with the car and need this to work!
    Turn on the View->Show Serial IO option.
    Then try logging data.
    Stop logging after about 5-10 seconds.
    Right click in the text area and select: Copy All.
    Paste the text into an email (or this thread) and I'll take a look.
    Jan 2009
    LOL i worked it out literally 10 mins ago. Thanks anyway.
  1. HELP, EFI live cannot detect pcm/ecm/tcm
    By bigblackdiesel in forum Duramax LB7
    Last Post: June 3rd, 2010, 03:29 PM
  2. Vibration/chatter under hard acceleration
    By LostCause in forum Lounge
    Last Post: January 20th, 2010, 02:42 PM
  3. V4 wont display chatter on vr commodore v6
    By Kevvrv6 in forum EFILive V4
    Last Post: March 12th, 2009, 05:11 PM
  4. VX and VY commodore
    By Thumper in forum Gen III V8 Specific
    Last Post: February 8th, 2009, 11:48 AM
  5. 07 VE commodore
    By ALRAJHI in forum Gen IV V8 Specific
    Last Post: October 6th, 2007, 08:44 PM
