Results 31 to 36 of 36
Thread: E38 LS7 EQ_RAT and EOILTS Issues
  1. #31
    All the SAE PIDs display LAMBDA for their value.
    Those PIDs are:
    SAE.LAMBDA displays lambda, even though (in EFILive) the description says "Commanded Equivalence Ratio". The description needs to be updated.
    SAE.WO2Sxx displays lambda, even though (in EFILive) the sub PIDs are called EQ_RATIO and the description says "Equivalence Ratio (Lambda)". The name and description needs to be updated. However, these PIDs are not supported on any vehicles that FlashScan is designed for - as the factory controller does not support wide band O2 sensors.
    The confusion stems from the fact that in previous docs the explanation of those PIDs was ambiguous. Sometimes it refered to air-fuel equivalence ratio (which is what we call EQ_RATIO) and sometimes to fuel-air equivalence ratio (which is what we call Lambda). Sometimes it even mixed up lambda and equivalence ratio.
    The latest SAE doc I have explain that it was wrong in previous docs and is now corrected.
    I should have updated the descriptions in the latest release but it slipped off the "whiteboard list" I've put it back on the list.
  2. #32
    Dec 2007
    Those PIDs are:
    Thanks Paul, appreciate the clarification. If even the SAE gets this out of whack, what hope have the rest of us mortals got?
  3. #33
    Member JAY4SPEED's Avatar
    Mar 2007
    Those PIDs are:
    Paul, has this been corrected as of 8/29/2009?
  4. #34
    No, but it has been corrected in the next update.
  5. #35
    Mar 2007
    Thanks Paul. I'm trying to shed my AFR "training wheels" and trying to start working in EQ ratio. Looks like the next update is going to be a good one .
  6. #36
    Actually, I just went to update those PID's descriptions and it has already been done in the previous release for generic (i.e. SAE) PIDs. Sorry for the confusion.
  1. What have the issues been with LMM'S?
    Last Post: September 22nd, 2009, 02:06 PM
  2. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 15th, 2009, 12:07 AM
  3. KR log issues
    Last Post: October 3rd, 2008, 11:58 AM
  4. Ok some serious issues
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 05:45 AM
  5. Issues with 7.51
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2007, 05:44 PM
