Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: E38 LS7 EQ_RAT and EOILTS Issues
    Jan 2009
    Default E38 LS7 EQ_RAT and EOILTS Issues
    When the ECM goes into PE I'm getting commanded EQ values of .829. I have dual LC-1s and these read AFRs in the low 11s so I know PE commanded EQ can't be what EQ_RAT is logging.
    Has anyone seen this?
    I was not logging commanded AFR so I don't know whether this is correct or not. In previous logs, closed loop AFR/EQ is 14.68/1.
    Also the GM.EOILTS always reads -40. ENGOILP and TFT read as expected and the oil temp gauges work. Is there another PID for oil temp that I'm missing.
    Dec 2007
    Quote Originally Posted by hapnermw View Post
    Are you using an LS7 Corvette calibration? Year? They typically dont have an oil temp PID, as the sensor does not connect to the ECM .
    As was in the previous post, the Oil Temp on most E38 applications is calculated. I am pretty sure the GM.EOILTS PID only shows what a real sensor would be reading if there was one fitted.
    Dec 2007
    And have only seen one calibration so far that expects to see an Oil Temp Sensor.
    I have a feeling it might be used on what GM call the heavy duty applications. They might have even wanted it for the Workhorse series, like Motorhomes etc.
    Jan 2009
    Quote Originally Posted by gmh308 View Post
    It's a 2007 C6Z06 stock calibration. I suppose that ECT and oil pressure is sufficient for the ECM.
    Jan 2009
    No one has commented yet on my issue with the PE values being output by the EQ_RAT PID.
    This is supposed to report the commanded EQ Ratio but its PE values don't seem to make sense. Has anyone else encountered this?
    Dec 2007
    That difference is typically what drives the re-scaling of the MAF so that the commanded value = the measured value for lambda.
    But there may be other factors, as you have not mentioned what mods are done on the car/engine, and someone who does this everyday may have some more feedback on whether the difference, which, though not knowing what low 11's is (11.05 or 11.35?) you may only be looking at a 7-9% error, and whether that is normal.
    Jul 2007
    Just a thought on the EQ_RAT PID. Is there a chance that its actually...
    "The commanded EQ ratio referenced to Stoich"
    14.68 x 0.825 = 12.17:1 AFR. Would this be what you are commanding in PE mode?
    Simon
    I may be wrong, but it seems to me that EQ_RAT is behaving like Lambda instead of EQ.
    Sanity check: have you set your fueling units to AFR or EQ and not Lambda...?
  1. What have the issues been with LMM'S?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 22nd, 2009, 02:06 PM
  2. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 15th, 2009, 12:07 AM
  3. KR log issues
    Last Post: October 3rd, 2008, 11:58 AM
  4. Ok some serious issues
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 05:45 AM
  5. Issues with 7.51
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2007, 05:44 PM
