Hey guys,
I read some info in one of the gasser threads from a guy wanting MPG from his duramax (going into a 1500lb hot rod?) and the basic info made sense, advance timing escpecially in the cruising range, but what about boost?
If you increase boost above stock would that not create a more complete and efficienct burn? And more torque at a given RPM?
What about fuel? Would you recommend an increase in fuel at the crusing RPM to create more torque, or simply optimizing the power already being produced through timing and/or boost?
I believe that an LBZ peaks torque around 1600 RPM or so, the milage tunes I've tried making for myself have been tested for anywhere from 500-700 miles at 70 mph avg.... one had increased timing and boost as well as 5% increase in pulse....the other had no increase in pulse but the other factors were identical. The tune with the 5% increase in pulse actually got better mileage. 20.5MPG at 70mph from north central Arkansas to east Tennessee. Not bad I thought considering the speed?
