Absolutely...
However, just to make this clear you said
"therefore simply turning up boost via vane position won't necessarily increase fuel consumption correct?"
You don't control the boost via the vane tables...
you control the boost via the boost table...
But yes... Fuel IS NOT referenced to the boost, it's the exact opposite. The boost is based on actual fuel delivery. not to be confused with desired fuel delivery.
