Results 1 to 4 of 4
Thread: RAFIG RAFPN for E40
    Senior Member MyM8V8's Avatar
    Aug 2008
    Default RAFIG RAFPN for E40
    I've been trying to get this done so I can get a good idle tune. I used the example PIDS kindly posted by SSpeedemon. As I am using the E40 with the LS2 do I need to change them for E40 specific ones and if so what are they.
    Reason is having logged, not all the pids have info' against them.
    Thanks.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Jul 2003
    I have wanted this also... as far as I know.. it isn't available... yet?
    Oct 2005
    IIRC they are calc pids and are based on long and short term idle trims
    If you look at the "more info" link you will see the actual PIDs they are calculated on. You need to select these pids first to allow the RAF pids to contain values.
    Usually selecting the calc pid and not the base pids warns you.
    BUT I just checked and the E40 is similar to the E38 in that the airflow tables are different to the LS1, so you are likely to need to mess with the min idle airflow table instead as well as perhaps base idle spark. With a cam etc maybe add a bit more timing and a little more airflow. (Gareth try 2* more idle spark and 1 or 2 g/sec more air)
    2014 VF SV LS3 Maloo.
    Jul 2003
    I am sure there are idle trims for the E38... but is there a way to log this or to "see" the correction?
  1. Trying to tune RAFPN and RAFIG
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: January 13th, 2010, 04:39 PM
  2. Tuning RAFIG and RAFPN NEED HELP PLEASE
    Last Post: December 28th, 2009, 02:24 AM
  3. Rafig/Rafpn not working???
    Last Post: January 2nd, 2009, 01:15 PM
  4. RAFIG/RAFPN when running with MAF sensor????
    Last Post: March 3rd, 2008, 12:57 PM
  5. Start-up Idle issues. This isn't a RAFIG/RAFPN issue
    By RandomHero in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2007, 10:34 AM
