Results 1 to 5 of 5
Thread: Excel DTC File from Husker Diesel....
    Junior Member husker_diesel's Avatar
    Mar 2009
    Cool Excel DTC File from Husker Diesel....
    Hello all....
    I have put together a little document that some of you might like to have around. This is a Excel file that stores all of the GM Diagnostic Trouble Codes.
    Here are the simple instructions:
    1) Click and download the attached .zip file to your desktop.
    2) Click and open the .zip folder on your desktop, and select extract all files, then you should see the Excel file, if you have MS office.
    3) Open the file and put your code in the box and press enter on your keyboard.
    4) Enjoy.
    let me know if anyone has any questions or suggested changes.
    _____
    Later,
    Jess
    Husker Diesel
    Thanks Jess, I know first hand it's quite a task keeping up with the DTC lists, they seem to just keep adding more and more.
    The need to add one more important one that would suit 99% of people and could replace 100's of existing DTC's.
    P9999 - Something is wrong, but you don't care, just keep driving.
    Lifetime Member LBZoom's Avatar
    Jun 2008
    lmao, that's hilarious....and true
    Sep 2006
    Very cool...Thanks for doing this...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Mar 2009
    HAHA Thats a good one Ross. I will add that to v1.01.
  1. Correct Fuel injector Excel calculator for EFIlive
    By 98 tigershark in forum Gen III V8 Specific
    Last Post: July 6th, 2009, 01:28 PM
  2. correct Fuel injector settings Excel calculator
    By 98 tigershark in forum Gen IV V8 Specific
    Last Post: July 5th, 2009, 07:12 PM
  3. Excel Pivit Tables!!!
    By Gelf VXR in forum Lounge
    Last Post: July 14th, 2008, 11:00 PM
  4. Help with Excel
    By joecar in forum Lounge
    Last Post: November 16th, 2005, 04:10 PM
  5. Another Excel Worksheet
    Last Post: August 16th, 2005, 03:38 AM
