Results 1 to 2 of 2
Thread: Can't add gauges in LT1_8051 file?
    Mar 2009
    Default Can't add gauges in LT1_8051 file?
    Have a 94 Roadmaster LT1, want to use the gauges to the full effect but I only see 4 setup.. (using LT1_8051).. but if I open up LT1_8051_M0_a, it has a full compliment of gauges??
    Using the eval license, if that matters.. just want to add some useful stuff to the dashboard to see how it looks (RPM, MPH, TPS, Coolant temp, volts, left & right O2's, Knock retard, air flow, knock sensor, ign advance) Basically, I would like to see the gauges similar to what is shown in the user manual "using dashboard display" page.
    Soooo, how do I add gauges? I can't right click a menu up on anything other than the blue ones.
    Wallyman
    Mar 2009
    heh, nevermind.. figured it out. Change the "dashboard" dropdown in the datastream properties..
    Wallyman
  1. Lost my gauges...
    By Z06-Dave in forum Gen III V8 Specific
    Last Post: October 24th, 2009, 04:41 PM
  2. Why can't I add gauges?
    By arubenstein in forum General
    Last Post: March 28th, 2007, 07:24 PM
  3. AEM wideband gauges
    By madprof01 in forum External A/D inputs
    Last Post: June 5th, 2006, 09:34 AM
