Results 1 to 10 of 17
Thread: Auto VE and MAF
    Apr 2008
    Default Auto VE and MAF
    Im slightly confused with the AutoVE tuturial does it only work with SD tuning! It never explains how to turn the MAF back on after your done or do you just not use AutoVE with a MAF sorry the newbie is trying to gain a better understanding of this! Im working on a 2000 camaro btw!
    Jul 2007
    Auto VE is done with the MAF disabled. If you chose to run a MAF after dialing in the VE, you'll need to reverse the step taken to disable it, then dial in the MAF so it is correct.
    Simon
    Senior Member exploder's Avatar
    Aug 2008
    I can't find a writeup on how to dial the MAF back in. Is there a autoMAF procedure out there?
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    239/255 .624 lift LSr grind
    16psi
    Meth injection
    PLX WB02
    Same as AutoVE but with MAF enabled, and...
    - if you're using analog AFR you have to use the B5001 BEN map for your wideband,
    - if you're using serial AFR, copy/edit one of the B5001 BEN maps to use EXT.WO2AFR1 as the data.
    Apr 2007
    I have never actually been able to tune the MAF using this method, I posted about it months ago, there was someone else with the same problem, but I never got any answer as to why, I think the car went really really lean after trying to turn the MAF back on. Joe, reading your post, could using the wrong data caused my issue?
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    Using the wrong data, or using Lamda as fuel units, will certainly cause problems...
    I don't remember that thread, I'll have to find it and reread it.
    AutoMAF seems to work for some vehicles and not for others, I don't know the reasons.
    Apr 2007
    Well maybe I am not as dumb as I think, but I never did get the MAF to work right on that one car. That guy is still driving it around with the MAF unplugged, he does not mind as SD works fine, but at some point I told him to bring it back so I can figure it out.....just for my own education....He could care less about it.
    Member poolshark021's Avatar
    Apr 2006
    I'm not sure if there is a tutorial for AutoMAF but I believe you have to set B0120 to 400 so it is always using maf only for airflow calculations. Otherwise it will use a combination of maf and speed density which will throw off your data.
    Jan 2007
    Quote Originally Posted by poolshark021 View Post
    Correct. Then just use BEN's same as for the VE table.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Quote Originally Posted by zapp168 View Post
    What year/model is it...?
  1. Where's the Auto Cal
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2010, 04:30 PM
  2. auto ve for e38?
    By shane in forum E37, E38 & E67 PFI ECM's
    Last Post: March 28th, 2009, 08:14 AM
  3. auto VE help
    By chevpower in forum General (Petrol, Gas, Ethanol)
    Last Post: October 15th, 2008, 05:13 PM
  4. Auto VE the way to go?
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 7th, 2006, 07:38 PM
