Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Auto VE and MAF
  1. #11
    Apr 2007
    What year/model is it...?
    It was a 1999 camaro LS1, We put in a cam, I did the auto VE, I got it tuned in pretty close, went back to MAF and it ran super lean, I got on here and asked why...was told to tune the MAF, did that and it still just went way lean. This was a while ago and the guy is just happy with it SD, then he took it off the road for the winter so I never did get it back to figure it out yet. I will try to find the post
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
  2. #12
    Apr 2007
  3. #13
    I'll have a reread of that thread...
    Hmmm.... post your tune/log files here.
    Sanity checks... did you:
    - check your wideband for correct output...?
    - check your B4001 IFR table...?
    - start from AutoVE with VE "corrected" (BEN's close to 1.00)...?
    - enable the MAF (DTC goes away)...?
    - set B0120 to zero/400...?
    - use the B5001 BEN map to paste-multiply-with-labels into table B5001...?
    You could try something... in OLSD (as setup for AutoVE) log DYNAIR [g/s] and MAFFREQ [Hz] and create a map that looks like the B5001 MAF table (use the B5001 BEN map as a template), and paste that into B5001... (also take note how much difference there is)... then enable the MAF (and only the MAF), set B0120 to zero, and log BEN, DYNAIR, MAF... post that log (and tune also)...
    Remember: keep the pid channel count to 24 or less (i.e. no more than 4 packets).
  4. #14
    Default Another thought...
    Are you distinguishing between when VE and Backup VE are used...?
  5. #15
    Apr 2007
    hquick had the same issue and he is posting here, maybe he solved it??
    Anyway....it was a while ago I don't think I have the logs
    I use this wideband as portable on several cars it worked ok before and after
    I am going to paste everything you said and hopefully this guy should be taking the car out of storage soon so I will dig back in again...as always...Thank you!
  6. #16
    Jan 2007
    I did have an issue with my WBO2 in that the power supply jack turned out to be a bit dodgy. As soon as I fixed that....my numbers went rich (opposite to what it was earlier).
    I haven't re-visited tuning the MAF as it's now in the shed! (the MAF that is).
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  7. #17
    Apr 2008
    well i have to go back and start over because when i tried to automaf i fucked something up!!!! Not a big suprise i guess but def a little scary my afr just went from 12.9 at wot to 15.3 eeeeeekkkkk and 4.3 KR!!!! Not sure what I did but here is the .tun anything you see that might help please lmk have cold beer for all!
  1. Where's the Auto Cal
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2010, 05:30 PM
  2. auto ve for e38?
    By shane in forum E37, E38 & E67 PFI ECM's
    Last Post: March 28th, 2009, 09:14 AM
  3. auto VE help
    By chevpower in forum General (Petrol, Gas, Ethanol)
    Last Post: October 15th, 2008, 06:13 PM
  4. Auto VE the way to go?
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 7th, 2006, 08:38 PM
