briefly explain the difference between the two and why or why not one would be chosen over the other.
Thanks,
Russ
Thanks,
Russ
Hi Russ,
As of now (this may change in the future):
V7.5 is the scantool/tunetool software and can do BBL on FlashScan V1.
V8 (was called V8.1) contains the BBL for FlashScan V2 (i.e. is not the scantool/tunetool software).
If you want to view logs and edit tunes, you need V7.5.
If you want to do V2 BBL and/or update V2 firmware, you need V8.
perfect!! Thanks!!
