Results 1 to 10 of 12
Thread: calc.pid help
    Nov 2006
    Default calc.pid help
    I'm trying to make a calc.pid in metric and imperial,
    PSI 0 36 0.2 "({SAE.MAP.psi}-{GM.BARO.psi})*0.145"
    kPa 0 225 0.2 "(({SAE.MAP.kPa}-{GM.BARO.kPa}))"
    I am getting this error.
    "SAE.MAP has no value with units psi."
    ? More information:
    Intake Manifold Absolute Pressure {SAE.MAP}
    Units: kPa
    Range: 0..255 kPa
    Units: inHg
    Range: 0..36 psi
    I recall long ago there was a mismatch between the scan.exe and tune.exe
    with inHg and PSI, could there still be a problem or am I writing this wrong?
    LC-1 WBO2
    Nov 2006
    Fixed it
    psi 0 36 0.2 "({SAE.MAP.psi}-{GM.BARO.psi})*0.145"
    LC-1 WBO2
    Jan 2007
    Damned case sensitive programs. Lol!
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Nov 2006
    yeah, lol
    The whole "SAE.MAP has no value with units psi." thing threw me off and
    I didn't even think to check my sloppy typing.
    LC-1 WBO2
    Units case sensitive, good one, I'll keep that in mind.
    Senior Member whackem04's Avatar
    Apr 2009
    Default help getting calc.ve pid to show up in pid list
    why does mine look different then the one in the Calc VE tutorial. I have tried replacing every calc_pids.txt file every different way and no matter what this is what i get.
    thanks for any help. This is driving me crazy.
    attached: log screenshot and .txt currently in config folder in 7.5
    01 GMC Sierra 1500 SLE 5.3 cam swap
    Tuned by ME (COS 5 - running strong and smooth)
    Try the calc_pids.txt file from this post.
    Replace 5.669 with your displacement (in Liters).
    Apr 2009
    Just tried and the same thing. Its as if Scan isnt reading the .txt or only parts. Oh and this same problem happens on another computer as well. Its called Volumetric Efficiency on my 2 computers and when i log, i get a whole bunch of zeros. I want it to look like it does in the tutorial.
    Use this calc_pids.txt file.
    Did you copy it to My Documents\EFILive\V7.5\User Configuration...?
    You won't get exactly the pids shown on page 4 in the tutorial (that page needs to be corrected).
    Apr 2009
    Ok say it is working in scan tool, how come i get the zeros when i log.
  1. Calc.ve
    By whackem04 in forum Gen III V8 Specific
    Last Post: October 1st, 2009, 03:14 PM
  2. AFR Calc
    By Bob's Garage in forum Gen IV V8 Specific
    Last Post: May 24th, 2007, 11:14 AM
  3. hp calc PID
    By pwilson22000 in forum General
    Last Post: July 25th, 2006, 12:58 AM
  4. CALC pids
    By purrvert in forum General
    Last Post: October 25th, 2005, 12:32 AM
  5. FJO Calc PID
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: July 4th, 2005, 03:45 PM
