I am installing EFI Live on my other laptop since my first shat itself, however everytime i download and install it i ge tthis error
any help ?
any help ?
You are missing the calc.pids.txt in
C:\Documents and Settings\My Documents\EFILive\V7.5\User Configuration.
If you moved it put it back, if you don't have it here is mine.
calc_pids.txt
LC-1 WBO2
OLS108,
Also check this: scantool Edit->Properties->Folders and set the User Configuration folder (5th one down) to the correct folder as mr.prick shows.
