Results 1 to 5 of 5
Thread: RR for LB7
    Junior Member GL4787's Avatar
    Oct 2008
    Default RR for LB7
    what are the advatages of a roadrunner PCM for the LB7. what all is capable with it in comparison to a standard PCM?
    03 ext long box LT 2500 LB7 - Merchant Auto leveling kit, 285/75/16 BFG all terrains, and some go fast stuff
    Difference is ANY table you see in the Tuning tool can be modified real time on the truck without needing to reflash the ECM.
    Oct 2008
    so does this work with DSP also?? and also, i could see my self doing something like when i killed my truck setting the high idle back to 600 without deactivating the DVT if i had the ability to change EVERYTHING on the fly.
    Yes it would work with DSP as well.
    There is no safety net with RR, if you command 3000uS of injection time at idle, guess what, you'll get it instantly! It's a powerful tuning tool, it's certainly not a toy.
    Jun 2008
    i wonder what that would do.....
    03 Silverado CCSB LT Summit White
    417rwhp / 898trq <-old numbers need time to get on the rollers again
    4" Straight Thru Exhaust, Suncoast IV W/ 1058, Amsoil everything, EFILive DSP5 tuned by me with some help from Nick, PPE lift pump, and a BD spinny thing
