Can anyone tell me how to scan the injectors to find out witch one is bad.
Diesel Duramax Lb7.
snap on scanner modus has injector cut out per cylinder is you truck smoking if so watch the exhaust as you cut out cylinders bad inj. when cut out will reduce smoke
You might also blend some acetone in your fuel mix to clean the cloged injector
