Results 1 to 10 of 11
Thread: Hanging idle
    May 2008
    Default Hanging idle
    Time to pick your brains again... Recently my idle has begun to "hang." Here's the scenario... I pull up to a red light, step on the clutch, pull out of gear, and the RPM's get stuck at 1600 on the way down. It happens maybe every other red light. The only way to bring it back down is to ease off the clutch in gear while on the brake and then release around 1000 RPM. Note that idle is set at 800 RPM. What do you suspect the culprit is??
    Thanks!
    Bobby
    Mar 2005
    easy, two things:
    throttle cracker in gear (a 3D table) & throttle cracker out of gear (a 2D Table).
    Log the PIDs, cruise up to a stop and watch the resulting log.
    The hang can sometimes be a result of both tables spilling over together as you hit the clutch. In the 3D table pay particular attention to the lower SPEEDS (note this is more speed dependant than rpm dependant). When you throttleoff the rpm drops to close to idle and stays there as the speeds rolls off to a gradual stop.
    Many throttle cracker tables have a lot of variation throughout the years/makes/models so you have to have a play around to get what suits your setup.
    Finally once the car is almost stopped and you clutch it the 2D table takes over. Sometimes a slight flair happens here too so simple reduce the values in the appropriate boxes.
    Mike
    "Just a tune > yeah right !!!! "
    Lifetime Member johnv's Avatar
    Jan 2005
    If it was fine, and has just started doing this, it could be a vaccume leak, check the PCV hoses for splits.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    May 2008
    Thanks guys. I'll do some experimenting and see what works!
    Bobby
    PS: [Entertainment at my expense...] Actually I was just trying to do some experimenting. Looked like about 1/4 tank of gas and went for a short drive and next thing you know I'm parked on the side of the freeway running "lean." Stupid gas gauge is lying to me! Jogged home, got the truck and a gas can, and got the car started. Then sitting in the garage I'm watching the gas needle sway slowly up and down. What the F! So before I start replacing parts, is there anything besides the fuel level sender that would be the culprit?? And my speedo does weird stuff too. Sometimes reads zero up until 20-ish and then slowly climbs to the appropriate speed. I assume once again this would be the VSS sensor?? I think I need a fresh C6 and do a motor swap and toss the rest of mine!
    Check for loose/dirty grounds.
    May 2008
    Grounds for the sensors or the gauges?
    May 2008
    I hope you say sensor because no-way am i brave enough to take the dash apart!
    Any grounds you can locate anywhere on vehicle.
    If several gauges on your IPC are behaving strangely, then it could possibly be related to the IPC (do your PCM pids show ok...?)... what car do you have...? You should be able to remove the closeout panel from under the dash and you should be able to see the back of the IPC and any ground/cables/connectors... you may need the service manual (wire diagram, ground locations, other various details).
    May 2008
    I have a 1998 C5 Vette. Actually now that you mentioned it, my speedo VSS pid shows the same thing as the dash gauge (i.e. reported speed is lagging my actual speed). So in that context, I suppose it would be the sensor ground or the sensor itself that needs to be addressed?
    Thanks, Bobby
    Yes, in that case, check all PCM grounds.
  1. Idle "hanging"
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 10:53 AM
  2. EFILIVE _TUNE.EXE HANGING...on startup
    By TFZ_Z06 in forum General
    Last Post: September 21st, 2008, 10:16 AM
  3. Newb help w/ hanging idle & logging
    By LS1-450 in forum Gen III V8 Specific
    Last Post: April 19th, 2008, 11:15 PM
  4. Hanging idle on stock LS7
    By Stoichiometric in forum Gen IV V8 Specific
    Last Post: March 21st, 2008, 08:37 PM
  5. Low hanging fruit and other newbie questions.
    By NewV in forum Gen III V8 Specific
    Last Post: December 6th, 2006, 04:04 PM
