Results 11 to 20 of 21
Thread: Loping Diesel
  1. #11
    Forgot I already posted this one...
    -Nemo
    2004.5 LLY Duramax, Compounds, EFILive, EvolvedMS.com 50" Trac Bars, DDP Injectors, PPE Pump, 4" turbo back exhaust, 6" Chrome Stack,
    ATS Trans w/ Triple Loc.
    Evolved M.S, LLC & SS Diesel Tuning
  2. #12
    Apr 2009
    ok well thanks for all the info it was really helpful
  3. #13
    Sep 2008
    Change your throttle based injection value to around 30 at 0% and idle rpm. I believe this is how I accomplished this IIRC.
  4. #14
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    In your throttle based injection table at 600 rpm and 0% tp. Change that cell to 32 or 34 or whatever number you feel is right. Then go into your main injection pulse table and highlight cells 3-20 under 30-40mpa. Then add 100%. This will make her lope really good. Play with it a little until it is were you want it. If it is to hard, then decrease that one TBI cell.
    Dan
  5. #15
    Apr 2009
    Quote Originally Posted by Nemo View Post
    Here is a video of my LLY lope idle... sorry the sound is bad quality, i took the video with my cell phone...
    http://www.youtube.com/watch?v=Nws4L...e=channel_page
    -Nemo
    nemo if you dont mind could i get that tune for my lly
  6. #16
    Quote Originally Posted by numberoneshooter View Post
    I PM'd you back...
    -Nemo
  7. #17
    May 2009
    hey guys i have a lly that lopes pretty hard. Go to throttle based injection quantity and at 0% throttle in the 600 and 800 rpm columns enter 42. also i used imperial units. the higher this number the harder the lope.
  8. #18
    Junior Member speedygoss's Avatar
    Mar 2009
  9. #19
    May 2010
    Default my lope tune
    http://www.youtube.com/watch?v=F9iPRIOXRTo
    2004 gmc sierra 2500hd lly zf6... southbend clutch ... fass fuel system
  10. #20
    May 2010
    I PM'd you back...
    -Nemo
    For whatever reason I couldn't pm you.. Anyway, could you also email me that LLY lope tune? I'd appreciate it.
    Thanks,
    Brett
  1. V8 BBL - Diesel (LBZ) problem
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: July 1st, 2020, 02:00 PM
  2. jump from gas to diesel....
    By 0rion in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 7th, 2010, 05:23 AM
  3. air to fuel on diesel
    By ZL1Killa in forum General (Diesel)
    Last Post: September 14th, 2007, 04:26 AM
