Results 1 to 8 of 8
Thread: Bench tuning power source
    Jan 2006
    Default Bench tuning power source
    Anyone using a plug-in 12v supply?
    Custom Tuning Services
    Nov 2006
    LC-1 WBO2
    Jan 2006
    It is the power requirements that I am really asking about. Are any of these powerful enough?
    Nov 2006
    The Bench Harness Tutorial shows only 12volts needed.
    LC-1 WBO2
    Aug 2008
    I use a RadioShack power source...Adjustable from 10volts-24volts 4.5amps max
    No problems whatsoever... I bought it for like $119.99
    EDIT:12volts-24volts 4.5 amps max
    FLASHSCAN V2 & AUTOCAL
    Nov 2006
    Link or part number?
    LC-1 WBO2
    Aug 2008
    Radioshack CAT. NO:273-1686 AC/DC adapter
    Mar 2009
    I just bought a harness from a guy and he included a lil 12v battery from radio shack that is rechargable it is some where around 4'' by 6" dont know the part number will look and see if it is on it when I get home, this is the set up he used for bench tuning.
    98 silverado 4wd excb 5.7l, zz4 cam,roller rockers, shorty headers, 0411 swap, Flash Scan V1 commercial
  1. How much power needed for bench top programing?
    By kbracing96 in forum Tutorials
    Last Post: August 28th, 2010, 09:59 AM
  2. MAF tuning with flow bench??
    By SweetS10V8 in forum Gen III V8 Specific
    Last Post: December 27th, 2009, 03:28 PM
  3. what to use for power source??
    By rpmauto in forum General (Petrol, Gas, Ethanol)
    Last Post: April 11th, 2009, 05:00 PM
  4. AutoVE tuning - mileage? power?
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 08:30 AM
  5. Power Source for WB02
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2005, 03:43 AM
