well i have a problem on start up in colder wheather it will go rich i think when its in open loop. latley on 1st start up it will die like it did in the log and when i restart it i gotta give it a lil gas then it smooths out. also when driving some times the idle will fall when i push the clutch in and go in to neutral. also it likes to fall or dip when im trying to park. this is the only problems i have with the car, just some minor idle things i would like to get rid of.
in the log when i 1st started it it stalled. restarted with a lil help, i let it warm up then i turned the wheel some to watch iac steps, then i was doing some revs, then i turned it off then restarted.
