Results 1 to 9 of 9
Thread: Sputters wont start
    Jun 2008
    Default Sputters wont start
    truck wont start unless i use silicone spray and it sputters at full throttle fuel is at 3500 psi and its requesting 5500 at idle
    Lifetime Member LBZoom's Avatar
    Jun 2008
    If you've modified the tune at all can you post your tune up for us to look at man?
    Also your stock tune if you can for comparison
    It all sounds rather odd.
    If you didn't reflash a tune in, maybe try disconnecting the battery for 30 seconds or so.
    Member Big D's Avatar
    Aug 2007
    tell us what gen engine you have
    Jun 2008
    its a 02 lb7 i had to do a full flash and lost my stock tune now i dont know what OS I'm supposed to run which could be a problem
    Jun 2008
    Summary
    Supported parameters available 115
    Validated modules available 7
    System readiness test (EPA) Not checked yet
    Specifically monitored tests Not checked yet
    O2 sensors tests Not checked yet
    Diagnostic trouble codes Detected
    History freeze frames Not checked yet
    Stream-Slow scan mode Supported
    Stream-Fast scan mode Supported
    Maximum dynamic packets 8
    PCM
    System Readiness Tests Results
    Specifically Monitored Systems Tests Results
    Oxygen Sensors Tests Results
    Diagnostic Trouble Codes
    P0380 "Glow Plug Feedback Circuit A" EPA ($10) "Powertrain Control Module (PCM)"
    P0489 "Exhaust Gas Recirculation (EGR) Solenoid Control Circuit Low Voltage" EPA ($10) "Powertrain Control Module (PCM)"
    P2141 "Exhaust Gas Recirculation (EGR) Throttle Valve Solenoid Control Circuit Low Voltage" EPA ($10) "Powertrain Control Module (PCM)"
    P2144 "Exhaust Gas Recirculation (EGR) Vent Solenoid Control Circuit Low Voltage" EPA ($10) "Powertrain Control Module (PCM)"
    P2227 "Barometric Pressure (BARO) Sensor Performance" EPA ($10) "Powertrain Control Module (PCM)"
    P0101 "Mass Air Flow (MAF) Sensor Performance" EPA Pending ($10) "Powertrain Control Module (PCM)"
    P0380 "Glow Plug Feedback Circuit A" EPA Pending ($10) "Powertrain Control Module (PCM)"
    P0489 "Exhaust Gas Recirculation (EGR) Solenoid Control Circuit Low Voltage" EPA Pending ($10) "Powertrain Control Module (PCM)"
    P2141 "Exhaust Gas Recirculation (EGR) Throttle Valve Solenoid Control Circuit Low Voltage" EPA Pending ($10) "Powertrain Control Module (PCM)"
    P2144 "Exhaust Gas Recirculation (EGR) Vent Solenoid Control Circuit Low Voltage" EPA Pending ($10) "Powertrain Control Module (PCM)"
    P2227 "Barometric Pressure (BARO) Sensor Performance" EPA Pending ($10) "Powertrain Control Module (PCM)"
    P0380 "Glow Plug Feedback Circuit A" MPH ($10) "Powertrain Control Module (PCM)"
    P0489 "Exhaust Gas Recirculation (EGR) Solenoid Control Circuit Low Voltage" MPHC ($10) "Powertrain Control Module (PCM)"
    P0522 "Engine Oil Pressure (EOP) Sensor/Switch Circuit Low Voltage" PHC ($10) "Powertrain Control Module (PCM)"
    P0530 "Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit" PHC ($10) "Powertrain Control Module (PCM)"
    P1094 "Fuel Rail Pressure Low During Idle or Decel Fuel Cut-Off (DFCO)" PHC ($10) "Powertrain Control Module (PCM)"
    P2141 "Exhaust Gas Recirculation (EGR) Throttle Valve Solenoid Control Circuit Low Voltage" MPHC ($10) "Powertrain Control Module (PCM)"
    P2144 "Exhaust Gas Recirculation (EGR) Vent Solenoid Control Circuit Low Voltage" MPHC ($10) "Powertrain Control Module (PCM)"
    P2227 "Barometric Pressure (BARO) Sensor Performance" MPHC ($10) "Powertrain Control Module (PCM)"
    C0222 "Rear Antilock Brake System (ABS) Channel in Release Too Long" H ($29) "Electronic Brake Control Module (EBCM)"
    C0221 "Right Front Antilock Brake System (ABS) Channel in Release Too Long" MPHC ($29) "Electronic Brake Control Module (EBCM)"
    C0225 "Rear Antilock Brake System (ABS) Channel Motor Free Spins" MPHC ($29) "Electronic Brake Control Module (EBCM)"
    C0226 "Left Front Traction Control System (TCS) Channel Will Not Move" H ($29) "Electronic Brake Control Module (EBCM)"
    B0026 "Left Front/Driver Frontal Deployment Expansion Control Circuit" H ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
    U1000 "Class 2 Data Link" HC ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
    History data
    Wow, nice list of DTC's.
    If you want, PM me your VIN and I'll see if I can get your stock tune for you.
    Got your VIN off another forum, see below for your stock file.
    Jun 2008
    Thanks goin to try it
  1. wont cold start
    By dlove in forum Gen III V8 Specific
    Last Post: October 21st, 2008, 01:30 PM
  2. Car wont' start, need some help!
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 10:08 PM
  3. New RR wont start the car
    By ntae in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 18th, 2007, 08:45 PM
  4. car wont start with COS#5
    By articSS in forum Custom Operating Systems
    Last Post: September 19th, 2007, 12:43 PM
  5. 408 with 90/90 wont start
    Last Post: March 20th, 2007, 11:38 PM
