I know there was a post a while back about how to get a message programmed to display at startup on the driver information center, but I can't find it... how do I do it and which trucks can I do it to? LB7, LLY, LBZ, LMM?
There's a "message" file located someplace under the EFILive file tree.
Okay,
I found that but I don't know what to do with it haha. I'll post up what it currently says right now. Also, if I change it...it will display the same thing on every vehicle right? Or can I make it for individual vehicles?
Interested also.
2007 CCSB 4x4 Duramax LBZ
Merchant built STG III Allison/ P. I. Race Converter
lots more mods
EFI Live V2 /DSP5 / Diesel Addiction Custom Tuning
2000 Silverado ECSB
6.0 LQ4 , TVS 1900 , Comp 226-224 114+4
Long tubes/Duals.
Built 4L80E trans/ P.I. 2600 Vigilante converter
EFI LIVE Tuning.
I think it worked on my 2008 TBSS, but its got an 02-06 cluster in it (GM didnt change the TB clusters).
It won't work on vehicles with a cluster that is on the Single Wire CAN bus.
is this a permanent message that can be added to the corvette clusters/?? at least the C5s.
No, it's only temporary and can't be made permanent.
