I normally use
ECM, ETCTP
But I normally log a manual.
I've had a look at a T42 and found that
TCM, ACCEP
Appears to the same, it's just data being read from the TCM instead of the ECM. So I guess it's a choice at the time of logging, but given ACCEP comes from the TCM, it's probably the one to log.
You have listed the PIDs as they would be used in BBL, so I'm guessing that's what you are asking about. In this case, you can use either, or even both, as BBL allows for logging PIDs from 2 controllers as the same time. If you want to log directly to the laptop, it's a bit different though as you can't log 2 controllers. In this case if you are working on the TCM, then log ACCEP as it come directly from the TCM.
Simon.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
