after a a full reflash i got a check engine, with the scaner it was the C.A.S i went to the scanner for relaring it didnt work. the car is running ok but the light is bothering me.
Were all your conditions met (foot on brake, engine at op temp, car in Park).
Rev until fuel cuts off then take foot off pedal?
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
good read for relearn procedure
