Results 1 to 7 of 7
Thread: LMM Max turbo boost
    Apr 2009
    Default LMM Max turbo boost
    Q: My concern lies with the Desired Boost ECT and Desired Boost IAT tables. Do they set up a max limit for boost?[/SIZE]
    My current tune has good power, but my turbo boost never generates more than 24psi. I am tunning with efi on an 08 LMM with ATS transmission so I have room to generate more HP, hoping I don't blow a head gasket. The future calls for new turbos, but right now i want a little more out of my stock turbo.
    When i study the tune parameters the Desired Boost Levels parameters should be taking me well over 24 psi. My concern lies with the Desired Boost ECT and Desired Boost IAT tables. Do they set up a max limit for boost? Is that a fair statement or am i missing something with the Boost control settings.
    Chuck Bondurant
    Duramax LMM
    EFI Live tuned -Idaho Rob
    ATS transmission
    Bully Dog - PMT gauges only
    MPI Twins
    40 Over injectors
    FASS Fuel System
    Fabtech 6" - 18" XD Addict Rims
    They aren't limiters, they are adders to the base boost tables for cold/hot weather conditions.
    Off the top of my head I don't recall but can you log desired boost on the LMM? If yes, log that as well as the vane positions to make sure everything is as maxed out as you are wanting.
    Jan 2008
    B2226 might be the case but even in stock form it allows up to 34 PSI
    Remember when tuning the desired boost; if in low altitude subtract 14.5 from the number in each cell to figure out what the boost pressure is actually going to be.
    Junior Member MadMaxx61's Avatar
    Jan 2008
    24psi is like running a stock tune I see a max of 41 psi on most of the tunes I run but anything over 40 I see the EGT go up like mad.
    2008 2500HD 4X4 LTZ Z71 6.6L LMM
    Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
    Things still need to put in: PCV Re-Route,Air Dog AD-200.
    Apr 2009
    My turbo gauge is a Bully Dog PMT. Maybe it is not reading the electronic turbo singnal properly? I will try logging first then up the desired boost.
    Chuck Bondurant
    Duramax LMM
    ATS transmission
    MPI Twins
    40 Over injectors
    FASS Fuel System
    Apr 2009
    So I have done some further testing. The PMT seems to max out at 24 psi with either EFI tune or using the smoky PMT "Extreme" tune. So I switched back to the EFI tune and used the scan tool. From that I am reading MAX boost of ~50 psi. From reading an earlier post the 50 psi is really equates 36 psi at sea level?
    I can close this thread by summarizing:
    What is the PMT reading for turbo boost and why do I still own one?
    Idaho Rob has some bad ass tunes!
    Chuck Bondurant
    Duramax LMM
    ATS transmission
    MPI Twins
    40 Over injectors
    FASS Fuel System
    Jun 2007
    look at what the gauges read at idle. the one that reads 0psi is the the psia or psi absolute. the one that reads 13-15 is the psi reading from the map sensor.
  1. Too much boost and Turbo Vane "TARGET" Position-LMM
    Last Post: November 5th, 2009, 09:27 AM
  2. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
  3. anyone have a sts turbo kit
    By pdasterly in forum Gen III V8 Specific
    Last Post: March 2nd, 2009, 12:27 AM
  4. STS Turbo
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 27th, 2007, 10:10 PM
  5. Turbo Help me Tune for Off the Line Boost Table (B913)
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2005, 01:46 PM
