Results 1 to 4 of 4
Thread: Any tips for tuning a 98 turbo?
    Apr 2007
    Default Any tips for tuning a 98 turbo?
    Please don't say upgrade to 99+...LOL
    I just got a 98 camaro SS convertable, I have my old STS system sitting in a box in the corner, It is calling me....LOL. I swapped my 98 WS6 to a 99+ so I could do it, but do I have any options with the 98 PCM if I don't get too crazy with the boost?
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    Apr 2008
    what boost r looking for?
    U can't download an OS on 98, so u might stick to 1 bar max. As usual, every 7 psi require (-)2 deg. Pull 4 deg at where the turbo start charging. After that make your AFR 11.5 ~ 11.7. and then start adding degs wherever needed.
    I prefer tuning it on dyno, always, at the begining make it as rich as possible .
    Regards,
    Odd Boy
    Apr 2007
    Quote Originally Posted by odd boy View Post
    Ya I tried that tune on my other car, it was so horrible with any boost level I swapped it to an 02 PCM(and then a 416 SC). The car would start to spool and drop into a "hole" of fuel (I started with a professional dyno tune, then I tweeked it, better but it still was never good). I was going to try and re-scale the MAP and run 2-bar cutting the resolution in half and see what happens. I am going to add a rising rate regulator to try and help the issue, but I am strongly considering a tune by HPtuner as it has a 98 2 bar setup. I am only looking for 10 PSI MAX.
    Apr 2008
    post your tune, pls
    Regards,
    Odd Boy
  1. Turbo Tuning Help
    By jckleewein in forum General (Diesel)
    Last Post: August 30th, 2009, 06:11 PM
  2. sts turbo tuning
    By xAustin in forum Vortec V6/V8 Specific
    Last Post: September 6th, 2007, 07:39 PM
  3. Autove tuning tips
    By MSGHUFF in forum General (Petrol, Gas, Ethanol)
    Last Post: January 2nd, 2007, 11:52 AM
  4. LS2 Tuning Experiences & Tips
    By oztracktuning in forum Gen IV V8 Specific
    Last Post: November 23rd, 2006, 12:45 PM
  5. Turbo & Tuning
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2005, 02:55 AM
