Results 1 to 10 of 12
Thread: AFR not what Commanded- lean no matter what i change
    Default AFR not what Commanded- lean no matter what i change
    Anybody,
    no matter what i change or try to command the actual AFR will not change.
    I added 20% across the higher half of the Main VE and nothing happened.
    Whats the deal?
    I have ran out of ideas and im clueless. Need help.
    Here is the tune and a log.
    Tryin to go Speed Density, Tried to go back closed loop from a old tune that worked. It had no changes and now its lean and not richening up when the PE settings are met..
    Using a LC1 and we did a Free Air Calibration right before this log. It didnt change anything and the problem still is there.
    Jun 2005
    For starters, look at B3618, B3605, B3648. Is that what you want PE and Commanded.
    Also B0101 looks to be work in progress.
    Theres more but that should get you going. Hopefully other members can articulate a little better on the areas above and the areas I didn't mention.
    Roy 98SSSSSS
    Jul 2007
    P0101 to P0103 under "Engine DTC Processing Enablers". These should be set to "C: Non Emissions". Setting them to "X: Not Reported" will result in the PCM not knowing that the MAF has failed and will still be using the MAF signal. I'm assuming that the MAF is still in place and plugged in, so the fueling will be set from the MAF tables, not the VE.
    Set the above PIDs to "C" and retry.
    Simon
    Nov 2006
    MAF or SD?
    Where are you making changes?
    How old is the sensor?
    LC-1 WBO2
    Speed Density
    Trying to make changes in the B0101 Main VE Table.
    The sensor is about 3 months old.
    We made some changes and now fixin to go try it.
    To sanity check your wideband, go back to CL (i.e. CLSD) and check that the wideband reports stoichiometric AFR when in CL.
    Are you seeing any of these DTC's: P0101, P0102, P0103.
    Also, set those 3 DTC's in C6001 to A (1 trip) or B (2 trips).
    You must have one of those DTC's trip in order to failback to SD.
    WE got it.. i changed everything that was suggested here and on Performancetrucks.net and its all good now.. Dont ask what was wrong..
    Thanks for the help.
    Thanks Joecar, we got it. i do believe it was the "DTC's in C6001 to A (1 trip) or B (2 trips)."
  1. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  2. “Un-commanded” AFR at WOT
    By Rontune in forum Gen III V8 Specific
    Last Post: July 3rd, 2009, 02:58 PM
  3. Commanded AFR goes lean at high MAP value
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2009, 04:24 PM
  4. Lean spikes commanded vs actual AFR
    By billyjo in forum Custom Operating Systems
    Last Post: January 24th, 2008, 05:58 PM
  5. commanded afr
    By 69camaro5speed in forum General
    Last Post: December 29th, 2005, 05:42 PM
