Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
Thread: My EFI Live LMM wish list
  1. #11
    To go in to reduced power with only the P02E8 in the background just seems odd.
    I just wish there was a way on these Bosch ECM's to just have a global "Not Fitted" type parameter. Set to 'No' and then all DTC's and processing for whatever it is gets bypassed.......hey, a guy can dream!
    P.S - Nice Chevelle on the website.
  2. #12
    ok, looks like I did not get the timing tables correct on the LMM, no wonder you guys have been scratching your heads.
    Revised cals will be out shortly, it should all make sense then. I made some incorrect assumptions on what certain tables were used for.
    Essentially by you shutting off the pilots the ECM was using a timing table specifically for no pilot injection, however, there is 3 of them, you only saw one!
  3. #13
    Junior Member OSUBeaver's Avatar
    Oct 2008
    Thank you very much Ross!
  4. #14
    Senior Member camcojb's Avatar
    Dec 2007
    man, that's great news. Thanks Ross! Can't wait to try it out. Only way I can shut the pilot off is with the fuel pressure pulse table. That's fine with me, so hopefully now these new tables will get the timing back up. I was using the Table A for no pilots, but it was still being limited. Had every table up including max allowed. I was puzzled for sure, now it makes sense...........
    This is the best part of your product, that you can actually have a board like this that communicates directly with the engineers that build the product (as well as many helpful members). Thanks again.
    Jody
    07.5 4X CC 2500HD, EFI Live, MBRP exhaust
    new updated website!
  5. #15
    Lifetime Member IdahoRob's Avatar
    Apr 2006
    Jody, I don't think your dead pedal is from the air valve, as you're the only LMM twin truck I have heard of this problem. One of the reasons I wanted you to load in another OS.
    The dead pedal issue is really wierd and I don't think it's in the tune because many others are running the same tune for many, many months without the issue.
    Thanks for the updates Ross, that is sweet!!!!! Good job Jody putting the problems into words!!!!
    2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
    2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
    1965 El Camino, duramax 9.6 @ 149MPH
    All EFI tuned by Adrenaline Truck Performance
  6. #16
    Dec 2007
    Quote Originally Posted by IdahoRob View Post
    lucky me.............. You're probably right, just that it all happened at once. Maybe I need to go back to the other OS and see if it happens. I know all the timing/pilot things didn't change with it but I'm now not positive that it ever limped with that OS. I am pretty sure, but not positive.
    Jody
  7. #17
    Jan 2008
    If you ever get the egt probes to work on the LBZ's maybe you could apply the same logic back to the air valve and shut it off... ???
  8. #18
    Apr 2006
    Ross, while your in the LMM stuff, I'm still having that issue with the DTC enabler not scriping over. I have to manually turn off certain codes after scriping. The culprits are;
    P041D-P041C
    P040D-P040C
    P040F
    P0403(2nd one)
    P2453(2nd one)
    Not sure if you have time, thought I'd throw it out there though.
    Thanks a bunch,
    Rob
  9. #19
    Rob, I'll have to pass that one on to Paul.
    Are you able to send him a sample script?
  10. #20
    Jan 2008
    Those tables got released today...
  1. TCM OS List
    By TBMSport in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 4th, 2010, 02:33 AM
  2. list of 411 pcms anyone?
    Last Post: April 19th, 2010, 10:49 AM
  3. how to get my pid list to v2?
    By 2004gmc in forum Lounge
    Last Post: May 30th, 2009, 10:52 AM
