Results 1 to 5 of 5
Thread: PID Conversion Required
    Junior Member boyley's Avatar
    Jul 2008
    Default PID Conversion Required
    Guys I have read umpteen threads regarding changing PIDs for BBL but am bambooseld by it all.
    If you dont mind can someone tell me how to put these PIDs in my V2. Its already setup for BBL but I need to modify the PIDS in E38 Auto F2.
    Heres what I want in there
    [Parameters]
    CALC.AFR_PLX1=1,4216
    CALC.BEN_PLX1_E38=1,4272
    E38.AFRATIO_DMA=1,-1
    E38.APCYL_DMA=1,-1
    E38.ESTCATDEG_DMA=1,4335
    E38.INVLVTMP_DMA=1,4338
    EXT.AD1=1,4376
    GM.INJPWB1=1,4647
    GM.KR=1,-1
    GM.TFT=1,4938
    GM.TRQTRANS=1,4857
    SAE.ECT=1,-1
    SAE.IAT=1,-1
    SAE.MAP=1,-1
    SAE.O2S11=1,5059
    SAE.RPM=1,-1
    SAE.SPARKADV=1,-1
    SAE.TP=1,5080
    SAE.VSS=1,-1
    EFILive Student
    Nov 2006
    Read the PID description.txt for your PCM in
    C:\Program Files\EFILive\V8\Documents\Pid Descriptions
    Example:
    99+ LS1 manual trans = LS1B_M_PIDs
    IAT = [1] Intake Air Temperature (°C)
    MAF = [2] Mass Air Flow (g/s)
    RPM = [2] Engine RPM (rpm)
    Copy the Pid Description to the options.txt
    Example:
    PCM, IAT
    PCM, MAF
    PCM, RPM
    LC-1 WBO2
    What vehicle/year/model...?
    Post your Options.txt file, we'll edit it.
    Jul 2008
    If you wouldnt mind Joecar then I can compare the two fo future reference. Mucho Gratis
    I take it I just drop the updated file back into the config files tab??
    EFILive Student
    Quote Originally Posted by boyley View Post
    That is correct...
    Try attached file and let me know if it works or not (look at PSL_24).
    To get the wideband AFR, you have to press ENTER while logging.
    BEN can't be done yet.
    I don't have an E38 or T43... anyone is quite welcome to test this file out.
  1. Some guidance required!!!!
    By topfuelman in forum Gen III V8 Specific
    Last Post: June 11th, 2008, 04:40 PM
  2. Help required
    By monaro308 in forum EFILive V4
    Last Post: May 7th, 2008, 12:14 AM
  3. Advise required by newbie
    By SA1 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2007, 12:10 AM
  4. Personal to Commercial required?
    By Happy Jim in forum Custom Operating Systems
    Last Post: September 11th, 2006, 08:56 AM
  5. Is THIS required equired to edit files?
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: January 15th, 2005, 11:20 AM
