Results 1 to 10 of 17
Thread: RoadRunner license??????
    Junior Member Rumble's Avatar
    Feb 2008
    Default RoadRunner license??????
    Trying to connect a new Road Runner with EFI Live on a 2002 Camaro. The drivers installed fine and we can connect to the RR, however I get an error after it connects that reads:
    RR is not licensed for use with EFI Live
    To enable the attached RR euipped PCM to operate with EFI Live, please enter your RR license details using the menu option Help/Register/EFI Live
    Then when I go to Help/Register/EFI Live it loops me page to the EFI register page with no tab or area to place the RR info.
    We are trying to fire this thing on an engine dyno tomorrow morning with SpearTech harness and innovate WBs.
    Please help ASAP!!!!!!!!!!!!!!!!
    Rumble
    2002 Z28 B4C
    430 cu.in., CAM motion, TH400, MW 9"
    10 pt. 4130 Wolfracecraft, weld in SFC,
    KOOKS, Jesel, Bogarts, Goodyears,
    Etc, et$, e$$, $$$
    "I can barely email, let alone TUNE"!
    So Im assuming you already have the proper RoadRunner license to use it with EFILive correct?
    Open up the Tune Tool, go Help->Register EFILive and your FlashScan device serial number and registration information should be in License 1. Where it says RoadRunner License put in all the RoadRunner information in and press okay. It is right under where your FlashScan serial number goes. That should do it!
    Feb 2008
    Thanks for the reply, but the problem is there is no field for any input for the RR unlock code. Yes I have the 16 digit unlock code and the RR serial number that came with the RR
    There is a field for the RR serial, but not for the RR unlock code.
    Rumble
    2002 Z28 B4C
    Etc, et$, e$$, $$$
    So you do have the RR serial in the License window correct?
    In the Tune Tool have you opened up the RoadRunner control panel? Im not sure if thats where it goes, I dont have a RR so all the fields are grayed out.
    I think Moates has a software program that is used to upgrade the RR, does the unlock code go somewhere in there?
    Feb 2008
    Yeah, the serial number space is there, and the RR window can be opend up and I can connect to the RR, but thats it. This is my first time using the RR, so i don't know what to expect.
    Rumble
    2002 Z28 B4C
    Etc, et$, e$$, $$$
    Hmm then Im out of ideas, are there any thread in this RR forum with more info?
    Nov 2006
    did you buy the rr and v1/v2 as a set?
    if not you will need to give your flashcan license and rr serial# to Blacky
    so they can be merged.
    [License.1]
    Serial=000000000000
    RoadRunner= serial#
    Type=Scanner
    Issued=20000101
    Key=????-????-????-???? < this is the license for both
    post a screen shot of the error message.
    LC-1 WBO2
    Lifetime Member limited cv8r's Avatar
    May 2005
    If you open the tune tool, click on help, then Register Efilive..., you shold get the same as the attached image.
    Flashscan serial - the serial number of your flashscan unit
    RR Serial - your RR serial number
    Type - Licence type you have purchased
    Issue date - Date the licence was issued
    Key - Should be the 16 letter unlock code.
    All this info should have been supplied to you by moates or efilive.
    hope this helps
    Feb 2008
    Thxs for all the replys. I am turning this over to the Tuner and he is calling Motes. All the gear was purchased new and all is legit. Just some glitch that we can't get past. If you look at my past post history you will notice that this purchase was made about a year ago. We will start the engine with another pcm out of the same car, then when we get the RR up we will switch over.
    Rumble
    2002 Z28 B4C
    Etc, et$, e$$, $$$
    Nov 2006
    Quote Originally Posted by Rumble View Post
    But was it purchased at the same time?
    Read this thread licensing a used roadrunner
    LC-1 WBO2
  1. What Can I Do with RoadRunner?
    By Chalky in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 14th, 2012, 07:55 PM
  2. Flashscan has license avail. but won't let me license PCM
    By Wasted Income in forum Purchase and Shipping
    Last Post: April 6th, 2007, 10:25 AM
  3. LLY Roadrunner?
    By Cougar281 in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 14th, 2007, 06:46 PM
