I will be doing some exhaust work soon. Will the LM-1/LC-1 WBO2's give quality readings in the stock after cat location with the cat's removed? Also, if I install LG long tubes, how far back should I install the WBO2s?
Thanks,
Bob
Thanks,
Bob
Yes, using the stock BXS2 locations is fine if you don't have cats. If you get a long tube setup, you'll want to keep it with in a foot or two of the collector.Originally Posted by bobfo
