Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: V1 Licensing Question
    Senior Member tatasta's Avatar
    Mar 2009
    I will have to check in the morning when I can get to the car. With the V1 just plugged into my computer, I just get the error that it is not connected (which I assume is normal).
    Prior to working on the 2002 OS setup, it always displayed my correct VIN on one license and the other was available.
    I will get back to you when I plug into PCM.
    1999 Trans Am - P&P LS6 Heads - TR224-112 - Procharger P1SC - Performabuilt Lvl 2 4L60E w/ 2800 Billet Stall - 9" Inch w/ 3.70s - LS6 Intake - Mac Mids - ORY - Gibson Catback - Suspension, Drag Radials, A bunch of Other Stuff
    Mar 2009
    Got some screenshots of pcm info today when I was hooked up.
    Still not sure how I lost my second license but here is the info.
    Thank you
ID:	5380   Click image for larger version.
ID:	5381   Click image for larger version.
    Can you show a screen shot of PCM info screen like the image attached.
    Mar 2009
    I will get a screen shot of that in the morning and get it posted. I was wondering if I was getting the correct info.
    Thanks,
    Robert
    Mar 2009
    Ok, hopefully this is the info that you have been trying to get out of me. lol I'm a bit slow at times.
    License #2, obviously, is locked to my pcm. License #1 is the problem. I loaded a tune, from the EFI Live repository on LS1Tech about the time I noticed my open license went away. Not sure how that would happen, though.
    Please let me know if you need anything else.
ID:	5393   Click image for larger version.
ID:	5394   Click image for larger version.
ID:	5395   Click image for larger version.
ID:	5396   Click image for larger version.
    I can't explain why there are two used licenses on that cable. I'll send you a replacement license asap.
    I noticed that your V1 is a Personal Scan and Tune. That can't be used to upgrade the OS in a PCM. To upgrade you need to do a full flash and only the Commercial version can do a full flash. So if you are planning on doing an OS upgrade you'd need to upgrade your V1 to a Commercial. (It's only $50, here: http://www.efilive.com/index.php?pag...mart&Itemid=56
    Robert, did you get the Commercial upgrade ok...?
    Mar 2009
    Joe,
    Just about to buy it today. I did, however, get a new license to replace the one that I lost. Not real sure how it happened but the people at EFI Live helped me out. Support here is awesome.
    I am baffled by one tuning question though. I will post it in my most recent thread if you would look at it.
    Thanks to all for the help with my license.
  1. V2 licensing question
    By Spindoctor in forum FlashScan V2
    Last Post: April 10th, 2009, 12:23 PM
  2. Question About V2 Licensing
    By VortechC5 in forum FlashScan V2
    Last Post: November 15th, 2006, 01:58 PM
  3. One more licensing question................
    By FreddyG in forum Purchase and Shipping
    Last Post: June 1st, 2006, 05:40 AM
  4. Licensing question..................
    Last Post: May 23rd, 2006, 11:25 AM
  5. Licensing question
    By Cougar281 in forum Purchase and Shipping
    Last Post: February 8th, 2006, 09:39 AM
