Results 1 to 10 of 18
Thread: V1 Licensing Question
    Senior Member tatasta's Avatar
    Mar 2009
    Default V1 Licensing Question
    Hello,
    I have searched for my specific question but could not find the info.
    I bought my V1 setup with two licenses. Recently I have been working on upgrading my 99 Trans Am's OS to the 2002's 12212156 OS (I think that is it). Anyway, my Flash Scan now shows both licenses used and none available.
    Is that common when upgrading an OS? If so, can I go back to my 99 OS and keep the other license? I will need it later this year for my other car.
    Newb question, I know, but that does not seem correct given it is only one PCM/VIN.
    Thank you in advance.
    1999 Trans Am - P&P LS6 Heads - TR224-112 - Procharger P1SC - Performabuilt Lvl 2 4L60E w/ 2800 Billet Stall - 9" Inch w/ 3.70s - LS6 Intake - Mac Mids - ORY - Gibson Catback - Suspension, Drag Radials, A bunch of Other Stuff
    Hi Robert,
    If you flashed the new OS into the same PCM (that previously contained your old OS), then FlashScan should have used the old (already-attached) license...
    The license is per PCM (a license attaches itself to the PCM serial number).
    If you are using an older version of the EFILive scantool/tunetool software, there was a bug where the PCM serial number was going to zero and a new license was used up when flashing.
    I notified Tech Support.
    Joe
    From the tunetool, display the V1 license window, and take a screenshot of it, and post here.
    Mar 2009
    Thanks Joe,
    I have not done the full re-flash yet. After I do, I will see what happened and post the results.
    Thanks,
    Bob
    You may have to update the software to build 84.
    Mar 2009
    Where would I look to see what build I am using?
    I have used the tool to check for updates and shows none are available.
    Mar 2009
    Default Screenshot for Joecar
    Joe,
    Sorry it took so long. Like I said before, I never did make the change to the 2002 OS. I just copied my tune to it. I am still running my stock 99 OS and may not go to the 2002 for a while. Anyway, it took my other license somewhere along the line.
    Thank you.
Name:	V1 Lisence.JPG
    Quote Originally Posted by tatasta View Post
    From the scantool or tunetool, go Help->About to see the build version.
    You should be at build 84.
    Bob,
    Did Tech Support get back to you regarding the license that got eaten...?
    Joe,
    Thank you.
    When you select the Tuning Tool menu option: Flash->Show PCM Info...
    what gets displayed for the PCM serial number? Does it match either of the two used licenses in your V2 cable?
  1. V2 licensing question
    By Spindoctor in forum FlashScan V2
    Last Post: April 10th, 2009, 12:23 PM
  2. Question About V2 Licensing
    By VortechC5 in forum FlashScan V2
    Last Post: November 15th, 2006, 01:58 PM
  3. One more licensing question................
    By FreddyG in forum Purchase and Shipping
    Last Post: June 1st, 2006, 05:40 AM
  4. Licensing question..................
    Last Post: May 23rd, 2006, 11:25 AM
  5. Licensing question
    By Cougar281 in forum Purchase and Shipping
    Last Post: February 8th, 2006, 09:39 AM
