I went into the scan tool, clicked maps (F11) went to open new map defintion file. I cannot find Main VE- AEM (2bar). I setup up a calc_pid for the AEM and it does work. Just cannot find it in the map file. Any help please. Thanks Thomas
2004 silverado rcsb 2wd 5.3, 3.42's, 4l80e w/hd-2 and yank 3200, 01 LS6 cam, walbro 255hp intank pump, edge products 60lbs injectors, sts rear mount, EFILIVE with help of Nelsonperformance.
The PID must be selected or uncheck the selected box in the map properties.
LC-1 WBO2
Doe you have the PID set up another way?
Like metric or imperial.
LC-1 WBO2
Well I believe problem solved, hope . I went to the map tab, "open new defintion map file" , say for example I opened " {B0101} Main VE LC-1 W02 BEN (2bar).map" had a line marked through it after I opened cause it's not selected in the pids, then after I opened it I went into edit map properties then went to the parameter drop list and selected (0) Wide Band AFR 1- AFR AEM and clicked Ok to open and a message box popped up and said "map has been modified. Save modifications before exiting, I clicked ok. Now at the top of the map tabe it says AEM_AFR(Average). Map table reads 15kPa to 285kPa like it should. So I guess thats right. I am gonna go make a log and see how it works. I been using EFIlive for a little over a month now, enjoy learning the software. Thanks Thomas
