Does setting the G0801 to NO keep the car from going into limp mode? Mechanical column lock bypass is already done, but customer is getting the "pull key wait 10 seconds" warning, and afterward car will only go about 2 mph.
TTT
No one has any experience with this?
Sorry Ed I have none.
Roy 98SSSSSS
Haven't had the steering shaft disconnected lately?
PowrMax Performance
100 mm PowrMAF
G0801 in my tune was set to 'NO' by GM for the 'Column Lock Recall'. I would try setting it to 'No" as I don't think it will hurt anything and might fix it.
Cured..........
