07.5 4X CC 2500HD, EFI Live, MBRP exhaust
new updated website!
I will get some data logs while at TS to see how my converter is doing on a full pass.
2007 2wd RCLB LBZ w/6spd Alli
Extra Air & Fuel
Still tweaking
I really feel this is a converter issue as I've personally raced a very heavy 8500+ lb, high HP LMM with a 1054 converter that locked everytime in 2nd gear without changing a thing in the stock tcm.
I believe that with the higher HP that we are now obtaining, the older converter styles are too loose.
2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
1965 El Camino, duramax 9.6 @ 149MPH
All EFI tuned by Adrenaline Truck Performance
Switched converters and lock-up is back. Unfortunately did not get to make a single pass down the strip while at TS because the drags were canceled and then I was at the truck pulls while they opened up the track for test & tune. The converter locked up fine on the dyno but I was not running my truck.
Extra Air & Fuel
Still tweaking
I sent my Hughes converter back for them to take a look at it. They opened it up and said it looked like new (looked as if the lock-up clutched had never applied). I re-explained the issues we are seeing with excessive slippage and the inability of the tuning software to influence lock-up under these conditions. The Goerend converter locks up hard in T/H and holds (and does not heat up the trans fluid fast due to less slippage). Dyno data logs were done while the truck was holding 4th gear under WOT so I have yet to get a full data log with the truck up-shifting through all the gears under WOT. I will be back on the track May 29th-30th for more testing and racing.
Extra Air & Fuel
Still tweaking
I am about to order a scIV kit (hopefully), should I be avoiding the 1058? The 1057 was originally recommended when I was looking into this, then the 1058 back in January.
I would avoid it, unless you aren't going to race the truck, or possibly if you are running a milder combo. You can still race with it, but it won't lock in second at the track with a boosted launch, so that does affect the et some. I still went 12.75 at 108+ with it that way, but now that I know that other converters will lock in second gear on, it bugs me that this one won't.
Jody
I just got a stage 3 with a 1056 with about 500rw. I havent had a chance to log, but I think it is not locking in 2nd and 3rd. I know it was locking on the highway even at WOT.
I having a 1054 installed tomorrow. Might be able to run it Friday night.
