Results 1 to 5 of 5
Thread: Dual purpose PCM pin outputs
    Lifetime Member Whippled 496's Avatar
    Sep 2006
    Default Dual purpose PCM pin outputs
    The PCM uses some pins as "dual purpose" outputs. For example, PIN #33 (green harness) on a GEN III LS1 PCM can be used as a FAN #2 control or as an Auto recirculation control. Can anyone tell me what other PINs have this "dual" functionality on a GEN III LS1 PCM and are they programmable via EFILive?
    2014 GMC 2500HD RCLB SLE
    LML / Allison
    Mar 2009
    You trying to hook up dual fans? I know on my truck it was #33 on the green connector and #42 on the blue connector, I think lol. I will have to double check.
    2004 silverado rcsb 2wd 5.3, 3.42's, 4l80e w/hd-2 and yank 3200, 01 LS6 cam, walbro 255hp intank pump, edge products 60lbs injectors, sts rear mount, EFILIVE with help of Nelsonperformance.
    Nov 2006
    Are you going to power something or use an input for reference?
    Blue Connector: (99+)
    Pin 41, Black, EGR Pintle Position Ground
    Pin 47, Grey, EGR Pintle Position Sensor 5V Reference
    Pin 55, Brown, EGR Pintle Position Sensor Signal
    pin 55 can be used for WBO2 input,
    when you have a cable that has no AD or serial inputs.
    LC-1 WBO2
    Sep 2006
    Quote Originally Posted by SUPERTRUCKER View Post
    Quote Originally Posted by mr.prick View Post
    No, I have the dual fans already. I was actually looking for a place to tap for fuel pressure and for a third fan output for my intercooler heat exchanger.
    LML / Allison
    Jul 2003
    Subscribing.. this would be interesting to make a nitrous system more ... seamless.
  1. Seed/Key, what is the purpose?
    By N0DIH in forum Lounge
    Last Post: December 2nd, 2012, 05:21 AM
  2. logging WB info using LC1 analog outputs
    By alwaysinboost in forum FlashScan V2
    Last Post: May 15th, 2009, 03:34 AM
  3. changing shift solonoid outputs
    By killalux in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 1st, 2009, 08:02 AM
  4. Delivered and Requested torque outputs?
    By DURAtotheMAX in forum Duramax LLY
    Last Post: March 1st, 2009, 06:28 PM
  5. COS 5 have outputs?
    By Highlander in forum Custom Operating Systems
    Last Post: November 7th, 2008, 12:49 PM
