Results 1 to 10 of 12
Thread: pids for AEM wideband
    Oct 2007
    Default pids for AEM wideband
    Im trying to open pids for my aem wideband in scan tool but am unable to find them. I just see others , like plx,lm1, f.a.s.t, etc.. Is there someplace to download them? Thanks
    Nov 2006
    What version of EFILive are you using?
    AEM is the first WBO2 on the list.
    You will need to select EXT.AD1/2 for it to be valid.
    Uncheck the supported box above the description column.
    LC-1 WBO2
    Oct 2007
    im using the latest version of efilive 7.5 with flashscan v2 and got it connected through serial
    Oct 2007
    im using version 7.5.5 build 83. The first wideband i see on the list is autronics.
    Nov 2006
    If AEM is serial. then you will need to select the serial PIDs
    EXT.WO2AFR1
    EXT.WO2EQ1
    EXT.WO2LAM1
    EXT.WO2ST1
    and select the WBO2 in the V2 itself,
    F1> F4> F4 scroll to WBO2 type> select AEM> OK
    LC-1 WBO2
    Oct 2007
    Ok found all of those except EXT.WO2EQ1 . Where is that one located?
    Nov 2006
    Quote Originally Posted by blazinblue View Post
    Oops.
    That is a calc.pid that I made for myself.
    It's not needed.
    *CLC-00-021
    EQ 0.0 2.0 0.3 "(1/{EXT.WO2LAM1})"
    EXT.WO2EQ1 F021 CLC-00-021 EQ External "External Wideband EQ"
    LC-1 WBO2
    Oct 2007
    I got it working thanks!
    Post some logs...
    Oct 2007
    trying the auto ve tutorial, here are the logs. car is 2000 camaro with 2002 OS, with lid, long tubes, tr230/224 cam. Can you guys look at the log and also let me know if my o2 sensors are working?
  1. wideband pid help......
    By blackbeast ss in forum Gen III V8 Specific
    Last Post: August 29th, 2009, 04:47 PM
  2. Wideband
    By pdasterly in forum Gen III V8 Specific
    Last Post: November 16th, 2008, 08:16 PM
  3. Need help with my wideband pls..
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2007, 01:47 PM
  4. fjo wideband
    By articSS in forum External A/D inputs
    Last Post: May 27th, 2007, 09:02 AM
  5. Which wideband O2?
    Last Post: May 4th, 2007, 11:10 AM
