Results 1 to 7 of 7
Thread: Pass through logs corrupt..?
    Lifetime Member samh_08's Avatar
    Oct 2008
    Default Pass through logs corrupt..?
    I am trying to do my AutoVE and I am running into issues. I have the latest builds of everything and my scan logs are all corrupt. Values jump all over the place. When I am just scanning, all the data is normal and good, but as soon as I try to go over my saved log it is all over the place.
    Please let me know ASAP.
    Thanks,
    Sam
    Nov 2006
    LOL
    Are all you logs coming out like this?
    LC-1 WBO2
    Oct 2008
    Haha Im glad you find humor in this. Yes, my last two logs have been like this. I've only taken probably 5 total logs though and the last two scanned normal and turned to this.
    Any idea
    Can you please log those PIDs again and once logging has started, stop it again. Then display the [Console F6] tab page and copy/paste the packet programming trace data into this thread. The data I need to see should look identical to this (except for the timestamps):
    11:29:06.122: Programming PID GM.AFR, into dynamic packet 0[0..1] offset: 0...
    11:29:06.154: Programming PID GM.DYNCYLAIR_DMA, into dynamic packet 0[2..3] offset: 2...
    11:29:06.179: Programming PID GM.IAC, into dynamic packet 0[4..5] offset: 4...
    11:29:06.204: Programming PID SAE.RPM, into dynamic packet 1[0..1] offset: 0...
    11:29:06.228: Programming PID GM.FTC, into dynamic packet 1[2..2] offset: 2...
    11:29:06.253: Programming PID GM.KR, into dynamic packet 1[3..3] offset: 3...
    11:29:06.278: Programming PID GM.TFT, into dynamic packet 1[4..4] offset: 4...
    11:29:06.303: Programming PID SAE.ECT, into dynamic packet 1[5..5] offset: 5...
    11:29:06.328: Programming PID SAE.IAT, into dynamic packet 2[0..0] offset: 0...
    11:29:06.352: Programming PID SAE.MAP, into dynamic packet 2[1..1] offset: 1...
    11:29:06.377: Programming PID SAE.SPARKADV, into dynamic packet 2[2..2] offset: 2...
    11:29:06.402: Programming PID SAE.TP, into dynamic packet 2[3..3] offset: 3...
    11:29:06.427: Programming PID SAE.VSS, into dynamic packet 2[4..4] offset: 4...
    11:29:06.452: Using scan mode: Stream-Fast
    On the log you posted, there seems to be a problem programming the TFT PID, it was placed at packet 0 offset 0, instead of packet 1 offset 4.
    Oct 2008
    Thanks for the quick help Paul. I think the screw up was on my side. I clicked the TFT PID while I was monitoring real time data, NOT while I was recording. I dont know if you aren't supposed to do that or not, but I figured it was still ok if I was just monitoring and not recording. If it shouldn't be doing this either way then let me know and I'll look into it more for you.
    Thanks again,
    Sam
    It sounds like a bug that we'll need to investigate here. I guess we never thought to test that scenario .
    The correct way the software should handle that, is to not allow new PID selections once data logging has commenced.
    Oct 2008
    Understood. Haha I guess I have a way of testing these odd ball scenarios.
    Let me know if you need anything else.
    Sam
  1. BBL/pass through issues on LBZ
    Last Post: December 5th, 2009, 06:09 PM
  2. Help with software going corrupt
    By kwhiteside in forum Gen III V8 Specific
    Last Post: October 19th, 2009, 04:33 PM
  3. Corrupt BB data
    By RevGTO in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 06:48 AM
  4. Can't pass emissions?
    By WS600 in forum Gen III V8 Specific
    Last Post: March 11th, 2008, 12:37 AM
  5. 1st Pass AT VE Tuning
    Last Post: July 12th, 2006, 02:32 PM
