Hello,
I was wanting some assitance with tuning a GTO LS2 6.0L with Procharger P-1SC-1 52lb Injectors.
OS- 12604792
With stock injectors AFR max 12@5200RPM before running lean. Max DC
With 52 lb injectors AFR pegged 10+ up to 4250RPM. leaning steadily to 13@6500RPM
(both details are for stock calibration)
This is the first LS2 with larger injectors that I have done.
I have tried to change fueling and injector variables but I am still to calibrate to bring aim tables true.
Has anyone had experience with this particular setup?
Are there any particular cals needed to make AFR correct?
Thankyou in advance.
Jon
