Here is an answer from Ed Wright about fuel trims and W/B readings. "THIS IS FROM ED WRIGHT--I MAKE NO CLAIM TO IT" I'm just passing the info on.
"Don't use a W/B for Non WOT tuning, you're wasting your time. Use fuel trims--Ed Wright"
"If you want to use a W/B for part throttle and idle tuning---Which I don't suggest(you will be very lucky if your fuel trims agree with your wide band) you need to turn off the air/fuel ratio toggling the PCM does most all the time.
To shut that off, set the P.E. minimum temps and RPM to zero, P.E. enable throttle angle to all zeros, and the P.E. vs RPM Air/Fuel multiplier table to all "1"s and the P.E. vs temp table to all zeros. Otherwise your wide band is likely going to be showing you junk numbers, which may or may not be even close to correct. Even then, many of the popular wide bands vary widely.
You would be better off using fuel trims. Wide bands (Accurate ones that is) are only for WOT tuning. If you set the P.E. like I listed you may very well find it is not lean where it now shows it to be lean.
Are you going to leave your vehicle in open loop all the time? If not, as I said before, your wasting your time. The PCM is still going to try to correct it. I'm betting you will eventually find your not lean where you now think you are. Rich will make one "bog down" the same as lean. Bogus lean numbers is what you will see at idle and part throttle, Never Bogus Rich. Less than half the vehicles I have tested over the years will show 14.7-1 air/fuel at idle and part throttle with a wide band. That is unless you set the P.E. parameters as I outlined earlier. That is due to the wide band trying to deal with the rich/lean toggling. See if you have some black on your spark plugs. The PCM won't toggle the fuel rich, lean, rich, lean in P.E. mode. It does that pretty much all the time otherwise. It does that to store oxygen in the cats. Even if you turn C.O.T. protection off, it still does that. If you want your wide band to be correct (assuming it is), put it in full time P.E. mode while you are trying to do your VE tables. When you re finished, and put it back into closed loop, you may very well find (as many others have) that your fuel trims are again whacked. Many guys are trying to tune these like you would a FAST, Bigstuff3, DFI, etc. Those don't toggle the air fuel Rich/Lean like the factory PCM. They aren't as complex as factory computers,and aren't intended for vehicles with cats."
Jeff
