look at B3647.1200rpm to 2800rpm in the 35 to 70 kpa map zone. You will need to set these to 14.68 for STFT.(EQ 1.0)
The Tremor at AIR
thats wierd because i can set the table to be 13.5 and when it gets there it stops triming but when it goes back to anywhere that says 14.68 it starts triming again. thats on my truck i mean. this one that were looking at is a buddys.
In that last log there was nowhere 14.68 was commanded long enough for STFT to ocur.
IIRC it only flashed through stoich briefly maybe 2 times.
The Tremor at AIR
ok yeah ill try that then thanks ill let you know
I think the question is whats keeping it from commanding stoich when it's not in the 1200-2800 35-70 kpa zone.
05 Silverado rcsb. forged 6.0,KBRacing front mount, TC-76, tuned with efi live.
yeah that is the questions but if its not in the 14.68 for long enoght it wont have time to start triming right? but mabye on start ups only will it have that problem because it takes 30 seconds or so for it take start triming after u start the first time not about during a run.
