Results 1 to 10 of 10
Thread: PID's, Option.txt?
    Member SGFastMax's Avatar
    Apr 2009
    Default PID's, Option.txt?
    im new with a v2 and im trying to scan and log. but i dont know how to select pid's and option texts on the v2. or do i have to do this from the computer first? help
    Do you want to:
    1. scan/log using FlashScan as a passthrough to the PC/laptop?
    or
    2. scan/log using FlashScan as a standalone data logger (i.e. Black Box Logging, aka BBL)?
    For option 1, just select the PIDs in the V7.5 Scan Tool software.
    For option 2, You can edit the Options.txt file using Notepad and enter the PID names that you want to log. The available PID names for Options.txt can be found in the appropriate text files in the folder:
    \Program Files\EFILive\V8\Documents\Pid Descriptions
    Each PID is listed with its channel count in square brackets. For best results try to keep the total channel count of all selected PIDs at or below 24 for LB7/LLY and 28 for LBZ/LMM.
    A new update for the BBL setup is currently in beta test. It has an easy to use front end for setting up both FlashScan and AutoCal with PID selections for BBL. A pre-release version should be available once the beta software is stable, probably in the next few weeks.
    Until then you'll need to edit the Options.txt file manually.
    Mar 2007
    This is the thread for bbl. Bump to the top!
    2007.5 RCLB 4x4 WT LMM 8594OS
    Jan 2008
    Why did you bump this? This is an old out dated thread. It's commonly known that you are supposed to use V8 (scan&tune) to setup BBL
    Paul posted this reply way back before scan&tune was released to the public.
    Mar 2007
    Because this is the only way I could change my PID's the POS V8 version I am using does NOT work and this DOES.
    So please explain to me WTF I am doing wrong.
    Are you using this version of V8: showthread.php?t=12834
    Nov 2006
    The software writes the options.txt now and it is
    much easier than having to do it with notepad especially if you aren't familiar with
    how it is formatted.
    LC-1 WBO2
    Mar 2007
    Thank You!
    I don't know if I am familiar with shit, but I'll know if something is changed.
    Have a look at these pics, in particular the one with the multiple arrows.
Name:	S&T - Black Box Settings - Scan Settings.png
ID:	7067   Click image for larger version.
Name:	S&T - Black Box Settings.png
ID:	7068   Click image for larger version.
Name:	S&T - Black Box Settings - Tune Settings.png
ID:	7069   Click image for larger version.
    Mar 2007
    I think I have it. Thanks.
Name:	V8 screen.jpg
  1. V2 switching option?
    By Cougar281 in forum FlashScan V2
    Last Post: June 9th, 2009, 08:12 AM
  2. Bad Injector...what's the best option?
    By LBZoom in forum Duramax LB7
    Last Post: April 29th, 2009, 01:11 PM
