does anyone know how to move all calibrations form one lmm tune to another lmm tune? the tune i downloaded has a different OS number than mine. but its an lmm tune.
Yes,
Go to dieselplace.com and download the stock LMM tune for that os#, then open the tune and load the tune you want as "alternate tune for comparison" then go to edit>create script, then save the script as something you recognize....now go into the stock tune from your os# and select edit>run script and select the one you just made, bam done!
Also don't forget to configure units on both tunes before creating your script...or else the script will create and save, it just won't work and you'll pull your hair out trying to figure out why.
