Results 1 to 8 of 8
Thread: Ford/Lincoln DTS scanning with EFIlive or Autotap?
    Oct 2003
    Default Ford/Lincoln DTS scanning with EFIlive or Autotap?
    Dear all,
    my wife's Lincoln LS 2001 [made by Ford Motor Company] has SES code. I was wondering if it could be possible to scan the code with EFIlive [which I have for my Camaro] or Autotap [used to use it on the camaro as well]. EFIlive has V1 cable, if that helps. All I need is to read DTS codes, which should be standard OBD-II. Therefore the question is if my scanning HW/SW can support Ford protocol [which should be SAE J1850 PWM vs. GM's VPW].
    An attempt to read Lincoln's PCM with EFIlive failed. Is it possible to change the protocol to get basic ODBII info?? Would hate to spend $160, which is what dealer wants for a simple scan.
    Nov 2006
    No Ford support, unfortunately.
    Supported Vehicles
    Autozone will read/clear your SES.
    LC-1 WBO2
    Mar 2007
    A member here named Team ZR1 or ZR-1 is a dealer for an aftermarket scanner called EASE. He praises it as being the best and although I've never seen it, it does sound promising.
    Maybe you should look into EASE before you throw away the $160.00.
    For the record, I'm not promoting EASE or Team ZR-1 or even his ability as a dealer (never purchased from him and don't know the guy except from internet forum-ing). Just telling what I know so it may help you.
    Stealth
    He's not on here, but on ls1tech.com.
    Oct 2009
    I haven't tried EFILive yet but my ATUSB will do fords. i'm not sure of other versions of at devices.
    Alex
    Quote Originally Posted by Stealth97 View Post
    Stealth
    Oh no, he makes an appearance again, what a .........unique person
    Lifetime Member Cougar281's Avatar
    Jan 2006
    I used to like the Ease product, but since they switched licensing modes (used to be you bought a mfg stream and where able to scan ALL of that Mfg, now you can only get a group, ie: 2001-2004 Mustang, or Chevy Vans, etc), their pruduct when straight down the tubes IMO. If you want a Universal scan tool, you might look at Autoenginuity,
    Lifetime Member MN C5's Avatar
    Mar 2005
    One who knows little but talks a lot
  1. Autotap & EFILive
    By s10mods in forum General
    Last Post: March 10th, 2011, 08:17 AM
  2. does efilive do general odbii scanning for non gm?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2010, 03:53 PM
  3. Replies: 10
    Last Post: October 3rd, 2006, 01:52 PM
  4. Need some help w/ AutoTap and my Ford...
    By ToplessTexan in forum Lounge
    Last Post: December 10th, 2005, 08:57 AM
  5. Replies: 0
    Last Post: November 8th, 2005, 03:22 PM
