Results 1 to 10 of 10
Thread: MAF calibrations
    Default MAF calibrations
    what would i need to tweak to get my MAF sensor to read correctly for my new cam.
    Feb 2006
    You would at least need to perform the AutoVE process with a wide bank O2 sensor input. Then you could have the MAF conform to the now correct VE tables.
    Al
    are all widebands loggable? i orderd the AEM one from jegs
    Feb 2006
    Nope they all do not support logging, I have had a couple that do not. Some have a 5 volt output (linear or non-linear) and some have a serial data output. Looking at the manual for the AEM Single Channel Wideband UEGO Controller Module, it has a 5 volt non-linear output.
    Al
    so i need a serial data output one to log correct?
    If you have FlashScan V2, you can log either serial or analog AFR (or both).
    If you have FlashScan V1, can log only analog.
    how do i connect my wideband o2 system to log? doesnt really tell me how to connect to the computer in the truck or the lab top
    From your wideband's user manual you require this info:
    - power/ground connections,
    - analog signal output/ground connection,
    - the voltage->AFR transfer function (an equation, or 2 points if linear, or multiple points if non-linear);
    You replace one of the NBO2 sensors with the wideband sensor (or drill a hole and weld in a bung);
    the other end of the wideband sensor connects to its controller;
    connect the controller's signal output/ground to FlashScan's analog input/ground;
    connect the controller's power/ground to a switched/fused 12V+ voltage source.
    If your wideband is supported then the scantool PIDs tab will show a calculated AFR pid for it...
    otherwise edit file My Documents\EFILive\V7.5\User Configuration\calc_pids.txt to create a calculated AFR pid using the voltage->AFR transfer function.
    Or, if you have FlashScan V2 and your wideband supports serial AFR output, you simply need the correct serial cable to allow V2 to read the AFR from the wideband controller using serial comms.
    if i replace one of my exesting o2 sensors must i reinstall it after or can i delete the o2 sensor as seeing how my ve tables will be right on?
    If you want to run OL you can leave CL disabled and not install your NBO2's.
    If you want to run CL and your wideband supports synthesized NBO2 signal output (like the LC-1 for example), then you connect the synthesized NBO2 signal output/ground to the NBO2 connector on the PCM wire harness (do it right, use a NBO2 plug).
    Otherwise, you will need to either reinstall you NBO2 or drill hole and weld in a bung for the wideband sensor.
  1. Rev limiter and E38 calibrations
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: December 10th, 2009, 06:58 PM
  2. Non-GM 4th Gen TCM calibrations
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: March 17th, 2009, 08:17 PM
  3. LBZ Calibrations
    By Ultimate Diesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 25th, 2008, 11:44 AM
  4. OS Calibrations
    By Spindoctor in forum General (Diesel)
    Last Post: May 7th, 2008, 11:11 AM
  5. 85mm MAF calibrations
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2005, 07:19 AM
