Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: LMM: Strange defuel
  1. #11
    So you simply loaded the Options.txt file from the download straight into your V2 and started logging? That works just fine but you have 0 control over your PID selection until you fire up Notepad and go edit the Options.txt file with the appropriate PIDs. It is located in the "C:\ProgramData\EFILive\V8\Config" for Vista and for 2000/XP "C:\Documents and Settings\All Users\Application Data\EFILive\V8". Look for the LMM Auto part in the file and look at how the TCM PIDs are added into the ECM PID section.
    You cannot log both the ECM and TCM using a laptop with V7, when V8 is fully released you will be able to but until then you need to use V2 BBL.
    If either of you need help setting up your Options.txt file let me know!
  2. #12
    Senior Member camcojb's Avatar
    Dec 2007
    thanks, but no application data in mine. Thought I had all the updates.................
    Jody
    07.5 4X CC 2500HD, EFI Live, MBRP exhaust
    new updated website!
  3. #13
    Feb 2007
    I'm not trying to log ECM and TCM at the same time. I'm just trying to log TCM with the laptop, and I don't have any available transmission PIDs.
  4. #14
    Dec 2007
    Quote Originally Posted by JoshH View Post
    same here.
    Jody
  5. #15
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Josh,
    I've looked at your tune...try table B1122 and see what happens, maybe just max it out
  6. #16
    Quote Originally Posted by camcojb View Post
    Jody
    Have you looked under your user name as well? Im not sure why the document says this (I copied it straight from the EFILive doc) but IIRC on my Win XP machines there was nothing in the All Users section instead it was under my user name.
    same here.
    Jody
    Hmmm...stupid question but have you guys validated the trans PIDs in the scan tool? Connect to the the TCM (File->Select Controller) then validate the PIDs for that controller (Info->Validate PIDs). Just selecting the TCM will not give you the PIDs until you validate them.
    If this doesnt work then maybe there's something deeper going on here that support needs to address. This is what I had to do when I scanned my P10 initially and again a few weeks ago when I connected to my E67 and again with my T42.
  7. #17
    Jan 2008
    Yes, you need to validate pids like scarab said. the 08 07 06 allisons are all the same. I have had zero problems logging mine.
    If this gives you problems i would suggest using BBL to log instead. Its a lot easier than you might think and it will log both TCM and ECM at the same time which is extremely helpful when trying to hunt down a little bugger like that.
  8. #18
    Feb 2007
    Quote Originally Posted by LBZoom View Post
    Josh,
    I'll give it a look and see what it does. Thanks.
    I thought that's what it did when the green bar was progressing across the screen when you connected, but I haven't tried it so I'll give it a shot. Thanks for the advice.
  1. Defuel affect
    By SGFastMax in forum Duramax LB7
    Last Post: May 5th, 2010, 12:59 PM
  2. LMM defuel
    By lawnboy01 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 30th, 2009, 01:16 AM
  3. defuel question
    By saltflat in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 2nd, 2009, 07:41 AM
  4. Killing Defuel?
    By Cougar281 in forum General (Diesel)
    Last Post: October 25th, 2007, 07:05 AM
