Results 1 to 3 of 3
Thread: Airbag disabling?
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Default Airbag disabling?
    Anyone know an answer for this gentleman?
    http://www.ls2.com/forums/showthread...1#post11461271
    TIA,
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Well, how long the SRS system is viable after removing power varies from mfg to mfg. In some, the SRS is dead after 30 seconds, others 45min-1 hour (Personally, I don't see the point of more than 15 seconds of backup power in ANY SRS system; You're NOT going to need SRS Deployment 15 minutes after power loss ). SOP should ALWAYS be to cut the battery cables before performing an extrication. As for disabling the SRS system for an Extrication, other than cutting the battery cables, the only other way would be with a mfg specific tool (Tech 2 for GM, for example) through the DLC, and in a wreck where you need to extricate victim(s), there's no guarantee you're going to be able to get at the DLC or that the data bus will be functional. Best bet is to be familiar with SRS system discharge times for various manfacturers and make SOP to cut the cables.
    Apr 2004
    Thanks for the information. I appreciate the help.
    Elmer
  1. disabling a rev limiter
    By bearmtnmartin in forum EFILive V4
    Last Post: May 6th, 2010, 07:36 AM
  2. disabling stock antitheft?
    By thedivineguy in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2009, 02:10 PM
  3. C6 A/C not Disabling Under WOT
    By 5 Liter Eater in forum Gen IV V8 Specific
    Last Post: December 8th, 2007, 05:07 AM
  4. 99 VT Calais V6 Supercharged, MIL & AirBag Light
    By snoopin99 in forum EFILive V4
    Last Post: November 27th, 2007, 12:05 PM
  5. Is there a way to shutoff the AIRBAG light on the dash..?
    Last Post: November 11th, 2007, 11:34 AM
