Results 1 to 10 of 10
Thread: Shift pattern selection
    Senior Member PSWired's Avatar
    Jan 2005
    Default Shift pattern selection
    One more question: is there any chance of getting the parameters that define when each shift pattern is used added? I can modify the "Normal" "Pattern A" and "Pattern B" shift patterns, but don't know when each one is used.
    If it's in there and I'm missing it, feel free to tell me I'm an idiot...
    1995 GMC Yukon 4WD 4DR
    5.3 "LMG" engine: E85 with AFM
    6L80e 6 speed automatic transmission
    Should be covered under the 'Shift Pressure' parameters section.
    Jan 2005
    Perhaps someone could clear these parameters up for me.
    I have three shift speed tables in my calibration (OS 24249179 CAL 24251803): Normal, Pattern A, and Pattern B.
    Normal is self explanatory.
    Pattern A is set to "Normal" at D7010, which is confusing.
    Pattern B is set to "Pattern 1" at D7011, which means nothing to me.
    What do each of the available options in D7010-D7011 correspond to? Some are self-explanatory. The GM 6L80e overviews claim that there is a performance mode that is enabled by "aggressive driving". Is there any way to access or redefine what qualifies as aggressive driving?
    Thanks...
    Mar 2011
    where? i dont see it anywhere?
    1970 AMC Javelin. AES 390ci. MAST CNC LS3 heads,DragonSlayer-Ultra rods, Vic.Jr., wilson, N-W 102 T/B, 95lb. "FIC 1000cc. injectors", Lonnies Performance twin pumps/harness. Twin TC-70-65's flipped manifolds, A/W intercooler, TH-400, Griner 1+2 trans brake, PTC converter, 3.50 gear 29-18.5-15 tires. Alston Battle Cruizer 4-Link, Fab-9. Cage, tubs, PSI harness, 0411 ECM. EFI Live,
    Aug 2010
    In the T43 calibration ... Shift Pressure folder ... parameters D7010 and D7011 are adjusted via drop down menu. Parameters D8010 through D8015 - may be set to Pressure Pattern A, B, or C.
    Pressure Patterns A, B, and C are adjusted via their respective folders ... on an individual shift basis.
    Regards,
    Taz
    Mar 2011
    thank you, but what everyone wants to know is, what is normal--pattern A--- pattern B,
    is normal when drive D is selected? is pattern A when sport S is selected? pattern B? for shift speeds such as D1001?? then shift pressures add pattern C
    Aug 2010
    Sorry about that ... your question in post #4 was "where" are these, not how do these work.
    As a disclaimer, I am the self-professed Gen III guy, and have only done a few Gen IVs thus far - so the following is my understanding, subject to correction / revision by a Forum member with more A6 experience.
    D7010 & D7011 are Shift Patterns - not pressure patterns. D7010 is often set to "Normal" - used when the shifter is in the "D" position. D7011 is often set to "Performance / Sport" - used when the shifter in is the "M" or "S" position (the very last detent - below the "D" position).
    D8010 through D8015 allow you to configure which Pressure Pattern (a component of shift firmness or "feel") are selected when in Normal mode (often D7010, D8010, D8011), Performance / Sport mode (often D7011, D8012 - D8014), or TAP mode (D8013 & D8014).
    Hopefully this answers your actual question ...
    Regards,
    Taz
    Mar 2011
    no, i cant seem to ask the right question.
    Please try again then because Taz's explanation seems pretty clear.
    Mar 2011
    ok i get shift patterns Normal, A and B, and how they go with shift pressures.
    what is shift pressure pattern C and how is it selected in the car.
    In the shift speed tables, Normal = selector in "D"
    Then pressure pattern A and B depend on tables D8010-D8015. Pattern B will be with the selector in S or Sport, pattern A will be in D Drive.
    I guess im getting confused in the shift controls for shift speeds, why do they list a normal shift speeds and also pattern A shift speeds? are they not the same thing?
    Im working on a 2009 Corvette A6
  1. What is Pattern A & Pattern B on the 2010 Camaro 6L80 Tranny Tune??
    By 2010 Bumblebee in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 5th, 2010, 09:06 PM
  2. Can I copy one shift pattern table from one folder to another ?
    Last Post: May 4th, 2010, 09:32 PM
  3. Engine Brake Pattern for C4500?
    By 577cc in forum Allison 5 & 6 Speed
    Last Post: January 2nd, 2010, 07:02 AM
  4. LB7/LLY Duramax crankshaft pattern
    By GMPX in forum General (Diesel)
    Last Post: May 27th, 2009, 01:46 PM
  5. Two switch shift selection
    By Biggsy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 8th, 2007, 07:57 PM
